Results 1 to 4 of 4
- 09-23-2011, 02:13 AM
Thread Author #1
A Case That Will Fit Over An EVO3D With A 3500 Extended Battery?
Is There a case that will fit over an EVO3D with a 3500mAh extended battery? I purchased it off of EBay, so I don't know who made the battery. There is a Seidio case that I saw on EBay and Amazon that fits extended batteries, but only ones made by them and only for the 4000mAh extended battery, not a 3500mAh one that I purchased. I'm looking for a case, not a holster.
Any suggestions? - 10-01-2011, 12:22 PM #2Thanked by:
- 10-01-2011, 04:19 PM
Thread Author #3
I purchased my extended battery off of Ebay and it doesn't have a brand name, and the extended battery cases that I have seen, will only fit over batteries made by the same companies that create the cases for them. So the only way to know if the case that you have will fit over the extended battery that I have, is to know the size that the battery adds to your phone. So if you wouldn't mind, can you please tell me what size your phone is with the extended battery? How closely the extended case fits over your extended battery/phone? Which manufacturer created your extended battery? And what mAh rating size is your extended battery? Sorry if I am asking too many questions, I just want to make sure that I buy the right case for my type of extended battery, because extended battery cases are much more costly then the ones that fit over the standard size battery.
Posted From My Sprint EVO3D Using Tapatalk -Last edited by the2ndflood; 10-13-2011 at 02:01 AM.
- 11-16-2011, 02:57 PM #4
Re: A Case That Will Fit Over An EVO3D With A 3500 Extended Batte
There is a seller on eBay (moretalktime) who sells custom TPU cases for a lot of phones including the evo 3d with the extended battery.
Thanked by:
Reply
