1. bishop793's Avatar
    I have been searching high and low for a controller for this game... i have it on my samsung tab 7 2.0, my Asus Memo pad 10, my HTC one x and my Galaxy note II and i totally suck using the touch controls!! I heard the Moga was compatible, then I heard that its only compatible for the demo version offered by t-mobile. Does anyone know of a controller that will work. None of my devices are rooted. Thanks.
    05-10-2013 10:15 PM
  2. Raymond Tan's Avatar
    What I did was to the local thrift store(goodwill, salvation army) and bought a streering wheel for a gaming console($7). I then modded a cheap universal tablet mount($8 on ebay) to attach my Note 10.1 to the wheel, and don't even have to remove my case. It can either sit on my lap or mount to a table. Plus it has a little resistance and it autocenters. It works perfectly for NFS Most Wanted, and I find I do a lot better with the wheel than without it. Although not really portable it works much better than any analog stick, and it's guaranteed to work with any driving game that uses tilt steering.
    05-10-2013 11:27 PM
  3. bishop793's Avatar
    Cool. how do you connect the wheel to the tablet? Usb? Bluetooth?
    05-10-2013 11:47 PM
  1. need for speed most wanted on nexus 4
    By jwl3429 in forum Google Nexus 4
    Last Post: 12-04-2012, 02:01 AM
  2. Replies: 0
    Last Post: 11-24-2012, 01:24 PM
  3. Need For Speed: Most Wanted now available for Android
    By smooth4lyfe in forum Android Games
    Last Post: 11-04-2012, 02:05 AM
  4. Need for speed shift not compatible with tb?
    By flashpiti in forum Verizon HTC Thunderbolt
    Last Post: 03-20-2011, 09:43 PM
  5. Replies: 1
    Last Post: 06-05-2010, 03:48 PM
