Help with power down.... Driving me nuts
stephanie85
83
4
I hope someone can help me with a question about powering down my Chromebook. When I am all done for the day I click the power off button at the bottom right corner where my little picture is and the Chromebooks little light in front turns from blue to orange.... But the light stays orange the entire night lit. Is that light suppose to be illuminated orange after a full power down? I assume the actual book is fully powered off since when I open the lid in the morning it takes about 8 seconds to boot and I have to re login. But the darn light is always on during the night. Any help would be appreciated.
selena650
62
Is it plugged into the outlet for charging? To shut off the laptop fully u have to go over to the right and hit the middle icon to power off.
selena650
62
Go over to the right of the Chromebook, click on the box, then click on the middle button to fully shut it down. I never use the keyboard power off. Also if its plugged into the charger then it will turn orange and it will shut off by itself when its done charging
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,569
4,700
113
How long are you pressing the power button to power off? If you just tap it, the Chromebook will just go to sleep. In order to power off completely, you need to press and hold the power button until you see your screen fade to white, then turn off completely.
kemberley1
