Results 1 to 2 of 2
    ddsdaltx's Avatar
    Posts
    Global Posts
    8 Global Posts
    Default ACER A500 SDCard/Internal Storage Problem ICS (Storage Low)
    I have the ACER A500 and I noticed that I was running out of space, so I deleted apps cleared out cache and it wasn't making a difference. Finally I started adding up the values from the different groups such as apps, photos, music and others and it didn't add up. There is a know problem that GPS writes out text files and they build up in the directory /data/gps. Acer has a fix listed in their forums but I could not get the update.zip to work for me and was getting the same problems as others in the thread, to go to the community website for this issue.
    I finally rooted my tablet and installed Superuser and Terminal software so I could manually delete these files.
    $ su
    # cd /data/gps
    # rm gl-*.txt
    It was able to regain about 8 gigs of space.
    I am going to monitor the ACER site to see if they get the update.zip file working correctly.
    Hopefully others will find this helpful.
    Thanked by:
  2. #2
    Default Re: ACER A500 SDCard/Internal Storage Problem ICS (Storage Low)
    same problem with phantom data use but i have no data/GPS folder at all...
  1. Storage problems after rooting...please help.
    By josh_evo4G in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 01-08-2012, 03:23 PM
  2. Choosing internal or exernal storage for Mass Storage
    By punkhawaiian in forum General Help and How To
    Last Post: 11-03-2011, 02:35 PM
  3. LG Vortex Storage Problem
    By Ramenstien in forum LG Vortex
    Last Post: 05-06-2011, 08:27 AM
  4. constant storage problem
    By ethan in forum HTC Droid Eris
    Last Post: 03-01-2011, 05:10 AM
  5. Phone storage problem. plz help!!!
    By henrykim in forum Verizon Fascinate
    Last Post: 02-27-2011, 06:19 AM
