1. jjfad's Avatar
    I think I would want something with at least 5-6 hours of screen on time.
    06-18-2014 04:20 PM
  2. Kilroy13's Avatar
    It should be pretty decent, it has none of the Google framework to deal with! The 720p screen will save power and still look good, at least it does on my flex
    Sent from my LG-LS995 using Tapatalk
    06-18-2014 10:16 PM
  3. robocopvn's Avatar
    has been using it for a week, with google framework and google play store installed.
    And the battery is great: considering I have been using LG G2 at the same time. The amazon fire phone battery performance is only a little bit less than LG G2.
    Note: I turned off all the dynamic perspective. because it makes me feel dizzy =DDD
    12-21-2014 02:39 PM
  4. Christopher Jacobi's Avatar
    I find battery life to be exceptional. I'm not running anything google on it so I don't know if that would make a difference. I'm on 4LTE for at least12 hours out of the day. Using email, web, maps, phone and maybe an hour or two of video and I'm always above 70% at 16 hours. I leave everything on with the exception of BT which I don't use.
    12-22-2014 06:34 AM
  5. Olga Xde's Avatar
    The battery time is OK. With WiFi always tuned on it lasts for 24 hours, which is GOOD.
    02-12-2015 03:33 AM
  6. Olga Xde's Avatar
    And when I text a lot, and make many calls (and still have WiFi on) it lasts for about 15 hours.
    02-12-2015 03:33 AM
  1. What phone are you getting next?
    By BluIndigo in forum Samsung Galaxy Note 3
    Last Post: 07-06-2014, 11:29 AM
  2. Potentially silly question about S View cover
    By S5_GJH in forum Samsung Galaxy S5 Accessories
    Last Post: 06-27-2014, 01:35 PM
  3. Tips for conserving the longevity of the Nexus 5 battery?
    By perhac181 in forum Google Nexus 5
    Last Post: 06-18-2014, 04:23 PM
  4. Where is my weather widget?
    Last Post: 06-18-2014, 03:09 PM
  5. is this fixable ??
    By 1Vicious9 in forum LG Optimus Series
    Last Post: 06-18-2014, 02:08 PM
