I accidentally deleted rom on my kindle fire. From TWRP screen, when I attempt to reboot the system it says, "No OS Installed!". Anyone brick their kindle this way? Is there any way I can fix this problem?
Printable View
You probably posted this in the wrong section, since I don't think the Kindle Fire HD's or the Kindle Fire 2 are running TWRP yet. Can you confirm that you are using the original kindle fire and not one of the three new ones that were just released?
If you do have the original kindle fire and it already has TWRP and FIRE FIRE FIRE on it all you need to do is download the rom you formerly had on your system, and the proper google applications for that rom and then flash them onto the device. The TWRP recovery software does have the ability to mount your device to a computer so once you've downloaded the rom and gapps you can simply copy it to the device (after checking the downloads with the md5 sum), do a factory reset, wipe the system, cache and dalvik and then install the rom followed by the gapps and reboot. Be careful and make a backup if you still have any important data on the tablet!
I have an original kindle fire running hashcode's rom which has been very stable and the only thing that doesn't work is the location capability (which for that tablet isn't important to me).
[Only registered and activated users can see links. Click Here To Register...]
If you have further questions or need more detail I can potentially do that when I'm home and have the table in front of me.
Do you know why suddenly my 9 month old Kindle Fire ( purchased in the States ) won't boot up ? I swipe the ornage arrow but no response and thescreen just fades. I've tried fully charging it but no luck. this is probably a very basic query to you so I'm hoping you can help as I use this for me e-mails etc. when I travel. Thanks.
Have you tried rebooting it? If you hold the power button for a long time it should power down. Then you can power it back up and see if that allows you to then log in to your fire.
Need help !
I've completely wiped my Kindle Fire (used TWRP) but without backup! So now I could not put any file to install a new OS. Please help me to solve it !! Great tks !
Haha, connect KF to PC then use Mount in TWRP can copy files (from [Only registered and activated users can see links. Click Here To Register...] ) and install the newest version!!! Haha LOVE TECHNOLOGY AND YOUR INTRODUCTION !!!! Have a good time !!!
