Do you guys keep your Kindle hd 8.9 naked or have you bought a case yet and what case do you recommend?
Sent from my SCH-I535 using Xparent Cyan Tapatalk 2
Printable View
I've tried several but found the Amazon branded case is the best for my needs. I just wish it was a bit cheaper. Its slim and very light and fits exactly to the Kindle.
Sent from my SPH-L900 using Tapatalk 2
I use the first case here [Only registered and activated users can see links. Click Here To Register...] it is a bit on the pricy side but it is doing a great job for my kindle HD
I went with an Otterbox Defender, because I have small children and it will get dropped/banged and want a little extra screen protection. I think I would prefer more of a flip case if it were just me using it, but the Otterbox delivers a good quality product that does deliver as advertised. I got mine for $60 on Amazon.
I use the M-Edge Latitude 360 case for my Kindle 8.9. Seems to be fairly sturdy, plus you can swivel the screen for horizontal or vertical viewing. About $35 at Amazon or medgestore.com.
I got this one. It seems to be fine.there are other colors available, but I didn't feel the need to make a fashion statement. :-)
Amazon branded case is the best.
John
I went for a case from Navitech, I found the case on Amazon but since buying it I have realised they have their own website which had the same case but for cheaper. The case provides plenty of protection which was important for me as I am a builder and use the tablet for writing up quotes. This case is available in 5 different colours as well.
For $6 this is a decent case to keep my wife's Fire HDclean and unscratched. 1,301 reviews, 4.5 stars. Not the slickest look, but very functional.
It depends on your budget. I have invested in this [Only registered and activated users can see links. Click Here To Register...]. It will put your kindle to sleep when you close the case and vice versa. If you wish something cheaper, the [Only registered and activated users can see links. Click Here To Register...] is also popular.
