1. Mel2Brad's Avatar
    I have been searching the web for a month for an answer to this issue with no luck.
    My son has a Kindle Fire HD since it came out and it has been a great device. But, when we updated to Mac OSX 10.9 (Mavericks) our Android File Transfer (AFT) app quit working the way it always had. Now, the Mac can't see the Kindle via USB. This was the only way we had to get movies from our DVDs onto the device.
    We our daughter a Kindle Fire HD 2013 for Christmas before we realized the issue. If I had known that I would not be able to download her crap ton of Disney movies onto the Kindle, Santa would not have bought it for her.
    I've tried updating the AFT app, restarting both the device and the Mac, multiple USB cords and ports. I have ADB enabled.
    I know there are a lot of people with other Android tablets having the same problem getting AFT and Mavericks to work and waiting for Google to provide a solution. Some are using Bluetooth instead of USB to transfer files, but that won't work for me because the movie files are too big.
    So frustrated. Has anyone heard of a solution?
    01-24-2014 04:59 PM
  2. Fenman's Avatar
    From what you say the problem has arisen from an update of your Apple Mac O/S
    With due respect why are you posting this on an Android Forum??
    Please ask Apple - they made the change that caused the problem!
    Why should Google supply a fix for a problem generated by Apple????
    01-26-2014 03:20 PM
  3. LazarX's Avatar
    I have USB transfer working just fine under 10.9.5 on my Hackintosh. if you have the Kies app installed on your Mac, that might be the problem.
    10-22-2014 02:20 PM
  4. GayleneMiller's Avatar
    Have you found an answer to your problem? I am having the same problem and Mayday support person is trying to research this problem.
    11-02-2014 02:51 AM
  5. GayleneMiller's Avatar
    could you explain what the kies app installed on mac is? we have the 10.9.5 on our mac and i have the kindle fire phone. I have had problems with this phone from the get go. I wish i would have stayed with apple products since they can't work together.
    11-02-2014 02:54 AM
  6. LazarX's Avatar
    It's the app I used to transfer files from my Samsung phone to my hackintosh AFT warned that it might not work if the app was not removed first.
    05-04-2015 06:54 PM
  7. LazarX's Avatar
    One way to work around your problem is to use Google Drive or Dropbox to transfer your files.
    05-04-2015 06:55 PM
  1. Note 3: Haptic Feedback not working?
    By Lilshaq65 in forum Samsung Galaxy Note 3
    Last Post: 08-26-2015, 11:12 AM
  2. Digital audio out with the LGG2
    By pjaizz in forum Sprint LG G2
    Last Post: 06-11-2015, 10:10 AM
  3. Help with my LG Enlighten
    By JD_015 in forum LG Enlighten
    Last Post: 01-24-2014, 06:15 PM
  4. Problems with playing videos on Facebook
    By henrodstone in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-24-2014, 02:41 PM
  5. People App confusion with SKYPE tm tags
    By John Campbell-Smith in forum Android Apps
    Last Post: 01-24-2014, 02:25 PM
