Results 1 to 5 of 5
    Ms Charli's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default No Numbers......Help
    OK just noticed that I can't type numbers on my Kindle I'm getting stul like @#$ instaed of 123 anyone else having this issue and if so is there a fix!!
  2. #2
    mungera's Avatar
    Posts
    Global Posts
    407 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: No Numbers......Help
    Can you give more info? Where are you typing? Is it all the time? Are you using the normal keyboard or the symbol keyboard?
    Ms Charli's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Adam Munger View Post
    Was typing in Facebook and it just started. I'm using a normal kindle keyboard but it's doing it on the symbols keyboard too.
  4. #4
    tiggrev's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Shift lock? (Just guessing, don't have my Kindle Fire nearby to check the keyboard.)
    Ms Charli's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    That could be it, I've been restarting my kindle when it does it. It does it periodically. Next time it acts up I will check and see if the shift is locked.
    Sent from my Kindle Fire using Tapatalk
