Results 1 to 6 of 6
    vlozano06's Avatar
    Posts
    Global Posts
    43 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery Drain
    I don't use the Kindle all that much, but the Kindle will be at around 70% one day and when I go to use it the next, the battery is dead. Without me even touching it all.
    Does anyone else have this problem? Is there something I can do to help with battery life?
  2. #2
    rmrashkin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery Drain
    Are you sure there's nothing still running. As an experiment, try shutting down the Kindle completely (press and hold).
  3. #3
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Codename Android / franco
    I get three days on average with use of reading books with kindle and web browsing, news apps, tapatalk, that amounts to three hours a day. On days with minimal use of one hour, I get five days of standby. I have Juice Defender Ultimate running on a one hour schedule.
    Using Tapatalk on a Kindle Fire with CM7 ROM
  4. #4
    KristyBake's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Maybe try controlling your settings, this usually is the biggest issue of battery drainage, Let me know how it goes!
  5. #5
    vivixgreg's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do you have to use the KF wall charger or will any mini usb work?
  6. #6
    NotJustAPhone's Avatar
    Posts
    Global Posts
    11,776 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    GS3: CleanROM / N4: AOKP
    Default
    Quote Originally Posted by vivixgreg View Post
    You can use a different mini USB charger but the KF charger has a higher output than typical chargers so your KF charges faster with its own charger.
    Sent using Tapatalk
