1. overmind2k's Avatar
    Hi everyone, I got an already rooted kindle fire (android 4.0) from ebay and it was running just fine for the last two weeks.
    until now, I only charged via usb on my mac. today I got an AC adapter for fast charging (2.1A) and very strangely, after plugging it in, the kindle just started the normal kindle OS instead of Android 4.0 (with actually the old owner's account singned in) and won't go back.
    I now set it to my own account, but I would like to go back to the Android 4.0 installation that I'm used to.
    Is there an easy way to do this, like a boot loader that let's you choose between the two, or just changing the default settings for startup somewhere? I don't know how it was rooted in the first place, but I found an app named "burrito-root" in the applications.
    thanks a lot. I didn't find anything concerning this with google, but I would also be thankful for links to obvious solutions, in case I just missed them ;-)
    09-21-2012 08:53 AM
  2. Little Darwin's Avatar
    I don't know what caused your issue, and have no personal experience, but I seem to recall reading somewhere that the way to get a Fire reset to the initial load was with some sort of special plug to use on the USB port of the Fire. Maybe somehow your charger trigered that reset. It is just a guess, but thought I would throw it out there.
    overmind2k likes this.
    09-21-2012 09:24 AM
  3. overmind2k's Avatar
    thanks for the answer, but has anyone a quick solution for this? I guess the Android 4.0 is still installed, I just would like to know how to start it....
    09-22-2012 07:16 AM
  4. muiriddin's Avatar
    When I had rooted my fire, I did not have a "dual boot" version installed. My guess is that when you cold boot your fire you would have to hit the power key once when the words Kindle Fire comes up on the screen This should then have a little menu down at the bottom of the screen which allows you to pick what you are booting into as I recall you have to pick your choice by pushing the power button once to move through each selection and then wait once you have highlighted what you want to start after a brief time it assumes you have picked your choice and it will start the one that is highlighted from that menu.
    Without knowing exactly which rom you have on the device this is the only suggestion I have...
    09-26-2012 03:06 PM
  5. charlibob's Avatar
    What usb cable did you use to connect to the fast charger? If it came with its own cable, it might be what they call a factory cable with pin 4 connected to 5v, not normally used for android devices.. That would reset the kindle. If so, you might have to re-root the device.
    10-28-2012 02:52 PM
  1. Copy Epic Apps to Kindle Fire
    By Sheepdogz in forum Sprint Epic 4G
    Last Post: 01-06-2012, 07:05 PM
  2. importing palm memos to kindle fire
    By dcchow2000 in forum Amazon Kindle Fire
    Last Post: 12-27-2011, 12:07 AM
  3. How To Download Video to Kindle Fire
    By TheNexusMan in forum Amazon Kindle Fire
    Last Post: 12-26-2011, 10:13 AM
  4. How to Soft Reset the Kindle Fire
    By charlibob in forum Amazon Kindle Fire
    Last Post: 12-17-2011, 12:47 PM
  5. How To Share Internet From Droid x To Kindle Fire
    By chrish9309 in forum Amazon Kindle Fire
    Last Post: 12-05-2011, 12:48 PM
