Results 1 to 11 of 11
- 11-10-2012, 11:48 AM
Thread Author #1
How to get Go Launcher Ex to work on Kindle Fire?
I've been trying to get Go Launcher Ex to work on my Kindle Fire, but after many attempts, still have to succeeded. Summary of what I've done (several times, with various variations):
1) set device to accept non-Amazon apps
2) installed AndroXplorer
3) downloaded Go Launcher Ex (ver 3.19, I believe)
4) installed Go Launcher Ex
Per a YouTube video, I should be able to click/execute Go Launcher Ex from a shelf on the 'installed Apps' screen, or from the carousel. Although I can verify that the app was installed (by exploring in the applications area of the settings), I can not get it to run.
Is there something I've not done, or something I've done wrong?
Thanks - 11-11-2012, 10:18 AM #2
- 11-11-2012, 01:12 PM
Thread Author #3
Re: How to get Go Launcher Ex to work on Kindle Fire?
I'm using the new (2nd generation) Kindle Fire. Do you have the first or second generation Fire?
From some other inputs, and my own investigations, I've come to believe (at least suspect) that it won't work on the 2nd generation Fire. I'm still hoping to find someone who's gotten it to work on that one. - 11-13-2012, 08:59 AM #4
- 11-24-2012, 03:49 PM #5
I am having the same problem. I have watched the YouTube video and downloaded the AndroXplorer and Go Launcher Ex. The app is there yet it will not open and at no point, hitting the Home button, am I prompted to choose Launchers. Any ideas why?
- 11-29-2012, 11:05 AM #6
- 12-01-2012, 08:59 AM #7
Same issue with the Kindle Fire 2nd generation (7" non-HD). Software version 10.2.1.
I installed the app using a file explorer but the app did not appear in the installed apps tab (on Cloud or Device) and I couldn't get it to run.
I tried several versions of Go Launcher EX with no success.
The app just mustn't be compatible with the Kindle Fire 2?
Edit: Bought in the UK.Last edited by Donna80; 12-01-2012 at 09:17 AM.
- 12-31-2012, 05:28 AM #8
- 01-20-2013, 05:58 PM #9
- 02-08-2013, 04:19 AM #10
- 03-14-2013, 03:47 PM #11
How to get the update Google Wallet working?
By NovaSS369 in forum Verizon Galaxy S3 Rooting, ROMs, and HacksReplies: 9Last Post: 08-27-2012, 05:13 AM -
How to get Kiwi PLX Wifi to work on Razr
By MarkBan in forum General Help and How ToReplies: 0Last Post: 03-13-2012, 05:03 PM -
What happens to the OE Home once Go Launcher EX is installed?
By Clandestine in forum General Help and How ToReplies: 6Last Post: 10-14-2011, 06:32 PM -
Go Launcher EX not working!
By poison81 in forum Android ApplicationsReplies: 14Last Post: 09-06-2011, 01:47 PM -
By poison81 in forum HTC myTouch 4GReplies: 2Last Post: 03-02-2011, 10:24 AM
Reply
