Results 1 to 2 of 2
    cjb44's Avatar
    Posts
    Global Posts
    69 Global Posts
    Question What's the difference between Fire and Fire HD?
    My 8 year old loves playing on the Fire HD and was I thinking about gettting him a Fire for himself (why spend the extra money if I don't have to?). Is there any reason that an eight year wouldn't be happy with the Fire instead of the Fire HD? Basically it's for simple games and TV/movies while traveling.
    He doesn't care about the resolution and will never fill the hard drive, but figured it was worth asking.
    Thanks in advance for any help.
  2. #2
    Default Re: What's the difference between Fire and Fire HD?
    He should be fine. You can play all the same games. The regular just doesn't have as fancy innards and the screen isn't as good but it works just fine.
    Thanked by:
    cjb44
  1. What is the difference between Rooting and Unlocking Bootloader??
    By coheed01 in forum Verizon Galaxy Note 2 Rooting, ROMs, & Hacks
    Last Post: 01-30-2013, 04:24 PM
  2. What's the difference between themes and ROMs?
    By Stang68 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 05-03-2012, 12:12 AM
  3. What's the difference between tethering and hotspot?
    By Lolanerd in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 02-28-2012, 11:25 PM
  4. What's the difference between Unrevoked3 and Unrevoked Forever?
    By tigerchant in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 11-28-2010, 01:26 PM
  5. What is the difference between Cyanogenmod/Koush and Ultimate Droid?
    By kalldrexx in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 04-24-2010, 10:13 PM
