1. r390a's Avatar
    So I 'inherited' my sister's old Kindle Fire last night, and decided to go ahead and root it this morning. I used thee Kindle Fire Utility v 0.9.9 to install TWRP Recovery, and then went on to install the Go launcher. Everything went well, but the Kindle app will not register with Amazon. I looked up the problem online and found some solutions, but none of them solved the issue. The app still says it is not registered, and to try registering again in a few minutes. Is there any way around this using the Lucky launcher? Will I have the same issues if I install Cyanogenmod?
    Thanks in advance for any advice you may have.
    12-29-2013 09:57 PM
  2. aspot72's Avatar
    As your device is rooted Amazon won't let you install anything... No matter what custom OS you flash. Only stock (non-modified) ROM will let you register.
    01-03-2014 06:08 PM
  1. Not happy with 4.3 calendar
    By 1812dave in forum Samsung Galaxy Note 2
    Last Post: 12-29-2013, 10:15 PM
  2. Touchwiz email app not receiving anything on 4.3
    By 7nexus7 in forum Samsung Galaxy S3
    Last Post: 12-29-2013, 09:43 PM
  3. Sprint GS3 mk3 android 4.3 root with knox
    By hax0620 in forum Samsung SAFE and KNOX
    Last Post: 12-29-2013, 09:27 PM
  4. Text messaging not working HTC EVO design 4g
    By LimuHead in forum HTC EVO Design 4G
    Last Post: 12-29-2013, 07:51 PM
