Page 9 of 9 FirstFirst ... 6789
Results 201 to 215 of 215
Like Tree20Likes
  1. #201
    Default Re: [Guide][Samsung] How to flash Stock ROM via ODIN
    Hey i dont know what im doing wrong but it keeps failing everytime. ive downloaded the stock ROMs multiple times and i keep getting the same result. any help would be appreciated
  2. Thread Author  Thread Author    #202
    Golfdriver97's Avatar
    Posts
    Global Posts
    22,237 Global Posts
    ROM
    Liquidsmooth ROM
    Try different cables and USB ports (don't use any hubs). Also make sure your PC drivers are updated.
    Phone Timeline
    'If we could change ourselves, the tendencies in the world would also change.' - Mahatma Gandhi
    Community Guidelines and also here
  3. #203
    I've tried everything. Got rid of Kies uninstalled the drivers and re installed them tried different ports nothing seems to be working.
    <ID:0/003> Odin v.3 engine (ID:3)..
    <ID:0/003> File analysis..
    <ID:0/003> SetupConnection..
    <ID:0/003> Complete(Write) operation failed.
    <ID:0/003> Added!!
    <OSM> All threads completed. (succeed 0 / failed 1)
    thats what i keep seeing on odin^
  4. #204
    I completely forgot to mention whats wrong with the phone. its a Galaxy Ace 2 e or SGHT599V and i had rooted it before and after a while i decided to unroot thats when it stopped working . it would stay at the samsung logo whenever id turn it on then i flashed it with the recovery after which all it would do is go into recovery mode when ever i turn it on. doesnt seem to be loading the OS just goes straight into recovery
  5. Thread Author  Thread Author    #205
    Posts
    Global Posts
    22,237 Global Posts
    ROM
    Liquidsmooth ROM
    I am actually not sure what to suggest. Sorry.
    Phone Timeline
  6. #206
    thats alright. i appreciate the your time though
  7. #207
    Thats alright. I appreciate your time though
  8. #208
    Hi, I'm using a Samsung Tab 3 or SM-T311. I rooted it with ODIN fine but now I want to unroot with flash but it keeps failing
    Please help.
  9. Thread Author  Thread Author    #209
    Posts
    Global Posts
    22,237 Global Posts
    ROM
    Liquidsmooth ROM
    Have you updated drivers, used different cables?
    Phone Timeline
  10. #210
    I have a big problem I was hoping someone could help me with. I have a Samsung Exhibit T679 and I wanted to root it. I was watching a video tutorial and I installed the Clockworkmod, rebooted my phone, did ROM wipe, then when I went to install the root-stock.zip it was not on my list. Now my phone goes into a boot loop. I can access the recovery page but my phone will not fully start up. Is there any way for me to fix this or do I need a new phone?
  11. Thread Author  Thread Author    #211
    Posts
    Global Posts
    22,237 Global Posts
    ROM
    Liquidsmooth ROM
    Quote Originally Posted by simified View Post
    If you have an SD Card, you can try placing the file there, and reboot recovery to flash the file.
    From an AOSP M8
    Phone Timeline
  12. #212
    I have a gnex and I tried this and it's stuck at the galaxy nexus X logo and nothing else is happened
  13. #213
    Just flash the factory image via adb or a toolkit. http://arstechnica.com/gadgets/2014/...-nexus-device/
  14. #214
    Lightbulb Re: [Guide][Samsung] How to flash Stock ROM via ODIN
    I have done flashing my Samsung galaxy S4 mini dous via ODIN but my phone is not starting now, only samsung logo appears and it stay like that for almost 30 mins so I decided to removed the battery, but when I power it again same problem occurred. Please help me.
  15. Thread Author  Thread Author    #215
    Posts
    Global Posts
    22,237 Global Posts
    ROM
    Liquidsmooth ROM
    Quote Originally Posted by mars6276 View Post
    I would pull the battery for a few minutes, after that, try rebooting into recovery (like download mode, but volume up) and clear the cache.
    From an AOSP M8
    Phone Timeline
  1. [Guide] How to use your Custom Recovery
    By Golfdriver97 in forum Ambassador Guides, Tips & How-To's
    Last Post: 10-01-2014, 11:23 PM
  2. [Guide] [Tools] File Extracting programs
    Last Post: 12-10-2013, 11:43 AM
  3. [Guide] [Supplemental] How to flash in Custom Recovery (Clockwork Mod)
    Last Post: 09-30-2013, 09:11 AM
  4. Dragging iTunes files to Nexus 4
    By itslikeimsayin in forum Google Nexus 4
    Last Post: 07-27-2013, 01:22 AM
