1. AlphaTango414's Avatar
    Download and install LG Drivers
    Download and install LG Flash Tool
    Download the correct stock firmware for your device.
    Place device in download mode. Power device off, while holding volume up, plug computer usb cable into your phone.
    Run the LG Flash tool .exe file
    Select “CDMA” as device type and "diag” as phone mode.
    Use the KDZ file you previously downloaded.
    Use" Normal Flash" to flash without losing any data. This is to fix system errors. Flashing anything besides the same current firmware will result in a boot loop.
    Use "CSE Flash" to wipe all data and flash stock firmware onto your device. Use this if you are soft bricked, boot looping, downgrading, sideloading update or just need to go back to 100% stock.
    Click start and choose your country and language in the pop up window.
    Hit ok and don't touch anything until it says 100%.
    Javier P and belodion like this.
    12-22-2015 04:28 AM
  2. Golfdriver97's Avatar
    Nice write up.
    01-08-2016 10:15 AM
  3. Jedandrei Ida's Avatar
    hi why my lg g3 f460s flash tools 2014 is 4% how to fix hlp me..
    02-10-2017 01:32 PM
  1. Some files not appearing in lg "downloads" app
    By CellTheUltimateAndroid in forum LG G4
    Last Post: 12-23-2015, 05:31 AM
  2. My Galaxy Ace s53801i is stuck on odin mode! How to reset it?
    By AC Question in forum Samsung Galaxy Ace
    Last Post: 12-22-2015, 07:03 AM
  3. my galaxy ace s53801i is stuck on odin mode! how to reset it?
    Last Post: 12-22-2015, 07:02 AM
  4. How do I get out of dm-verification fail?
    By BrookePerry94 in forum General Help and How To
    Last Post: 12-22-2015, 04:40 AM
  5. Why is my Moto G 2(2014) unable to update?
    By AC Question in forum Moto G (2014)
    Last Post: 12-22-2015, 04:21 AM
