DEAL OF THE DAY: Save 37% on the Seidio SURFACE Case for Samsung Galaxy S4!
Results 1 to 6 of 6
    Default Rooting problem for Samsung Galaxy Y Duos
    Hi,
    I have a Samsung Galaxy Y Duos phone running Gingerbread 2.3.6.
    I tried rooting the phone using the root kit in and am seeing the fwg error messages. Appreciate any help on resolving this!
    Easy rooting toolkit (v4.0)
    created by DooMLoRD
    using exploit zergRush (Revolutionary Team)
    Credits go to all those involved in making this possible!
    ---------------------------------------------------------------[*] This script will:
    (1) root ur device using latest zergRush exploit (21 Nov)
    (2) install Busybox (1.18.4)
    (3) install SU files (binary: 3.0.3 and apk: 3.0.6)
    (4) some checks for free space, tmp directory
    (will remove Google Maps if required)[*] Before u begin:
    (1) make sure u have installed adb drivers for ur device
    (2) enable "USB DEBUGGING"
    from (Menu\Settings\Applications\Development)
    (3) enable "UNKNOWN SOURCES"
    from (Menu\Settings\Applications)
    (4) [OPTIONAL] increase screen timeout to 10 minutes
    (5) connect USB cable to PHONE and then connect to PC
    (6) skip "PC Companion Software" prompt on device
    CONFIRM ALL THE ABOVE THEN
    Press any key to continue . . .
    --- STARTING ----
    --- WAITING FOR DEVICE
    * daemon not running. starting it now *
    * daemon started successfully *
    --- creating temporary directory
    mkdir failed for tmp, File exists
    --- cleaning
    rm failed for *, No such file or directory
    --- pushing zergRush
    441 KB/s (23060 bytes in 0.051s)
    --- correcting permissions
    --- executing zergRush
    [**] Zerg rush - Android 2.2/2.3 local root
    [**] (C) 2011 Revolutionary. All rights reserved.
    [**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
    [+] Found a GingerBread ! 0x00000118
    [+] Found a Samsung, running Samsung mode[*] Scooting ...[*] Sleeping a bit (~40s)...[*] Waking ![*] Sending 149 zerglings ...[*] Sleeping a bit (~40s)...[*] Waking ![*] Sending 189 zerglings ...
    [-] Hellions with BLUE flames !
    --- WAITING FOR DEVICE TO RECONNECT
    if it gets stuck over here for a long time then try:
    disconnect usb cable and reconnect it
    toggle "USB DEBUGGING" (first disable it then enable it)
    --- DEVICE FOUND
    --- pushing busybox
    3270 KB/s (1075144 bytes in 0.321s)
    --- remounting /system
    mount: permission denied (are you root?)
    --- checking free space on /system
    107 KB/s (439 bytes in 0.004s)
    df: /mnt/.lfs: Function not implemented
    --- Free space on /system : 21092 bytes
    --- no cleanup required
    --- copying busybox to /system/xbin/
    /system/xbin/busybox: cannot open for write: Read-only file system
    --- correcting ownership
    Unable to chmod /system/xbin/busybox: No such file or directory
    --- installing busybox
    /system/xbin/busybox: not found
    --- pushing SU binary
    failed to copy 'files\su' to '/system/bin/su': Read-only file system
    Unable to chmod /system/bin/su: No such file or directory
    --- correcting symlinks
    rm failed for /system/xbin/su, Read-only file system
    link failed Read-only file system
    --- pushing Superuser app
    failed to copy 'files\Superuser.apk' to '/system/app/./Superuser.apk': Read-only file system
    --- cleaning
    --- rebooting
    ALL DONE!!!
    Thanks for any suggestions.
    SG
  2. #2
    Default Re: Rooting problem for Samsung Galaxy Y Duos
    Download this:
    Put it on your root of your sd card,then turn off your phone wait till the battery bar shows up then you hold up the volume button the home and the power button,then you wait when it shows up samsung galaxy y the start logo, you keep holding it till it stop showing the logo and then show it again...you are in the recovery menu now just use the volume buttons to go up and down choose update find update.zip its gonna take 2 secs and you are ready
    Thanked by:
    Fantastic tool. Worked like a charm.
    Tx a bunch!
  4. #4
    i am still getting error in rooting i.e., e/unable to mount/sdcard
  5. #5
    Hi,
    Can you please upload the file again. Link is down
    Thanks
  6. #6
    Great tool.
