Hi,
I have got a HTC Desire S with Android Version 2.3.5
Recently i found that left side if my screen is not responding to touch, it's about 0.5cm or 5 mm which covers the whole (top till bottom) left part of my screen i.e. including my Home button. I checked on the internet and found recommendation to replace the digitizer, since i am not good at electricals, didn't dare to try it so far
What i need is either to change the resolution of my android phone by which there will be a black border on both side of the screen or have a notification bar kind of software (which runs over and above of all apps and forces other applications to re-size because of it's presence)
I searched on Google and found users changing resolution by changing density, but this will not help in my case as a part of my screen is spoiled.
Thanks in advance and any kind of suggestion is always welcomed
Regards,
Sach
Regards,
Sach
