1. Jo Lee1's Avatar
    Hi guys,
    I'm having an issue with my Samsung Galaxy Y where my phone ringtone is working but my notification (messaging) ringtone is not working.
    1. I think this started happening after I swapped SD cards. Swapping it back does not fix it.
    2. I've tried all of the notification settings alterations. I can assure you that they are all fine.
    3. When you are selecting a ringtone in the notificatoin -> phone ringtone menu, if I tap on one of the default notification ringtones no sound is played.
    However, if I click on a custom ringtone then I hear a sound. But when I receive a text, it only vibrates.
    4. I have not tried a factory reset and would rather avoid it.
    5. Ringtone apps do not fix it.
    I am by no means an amateur user so I would appreciate it if some constructive feedback could be offered!
    If anyone has had similar issues / know the solution please enlighten me!
    Thank you!
    09-22-2013 04:51 AM
  2. Haalcyon's Avatar
    Hi Jo, welcome to Android Central! A couple questions...
    Are you rooted?
    Are you running a custom ROM?
    09-22-2013 06:48 AM
  1. If your not using default ringtones what are you using?
    By Omer San Gabriel in forum Samsung Galaxy S4
    Last Post: 09-22-2013, 01:13 PM
