1. stelios85's Avatar
    Hello, I am encounting a mysterious problem:
    PROBLEM DESCRIPTION
    Sometimes, the mobile data connection seems to be connected (the arrows are coloured) but the connection doesn't work.
    I can't find a rule about a specific factor that causes this malfunction.
    SOLUTION ATTEMPTS
    I tried to solve the problem by:
    • disabling and re-enabling data connection
    • enabling and re-disabling flight mode
    • using some applications from google play which promises to fix data connection issues
    • cache cleaning
    • ram cleaning
    However, I discovered another solution that permanently solves the problem for specific apps:
    1. When the problem occurs, I open an application that needs internet connection.
    2. I test data internet connection through this application to be ensured that it doesn't work.
    3. I disable data connection, enable wifi and test if the application now has internet connection through wifi.
    4. I disable wifi connection, re-enable data connection and test again if the application now has internet connection through data connection.
    5. Data connection now works normally only for the specific application but not for other applications. Doing the same steps for another application the problem can be also solved for the other specific application.
    After these attempts I wonder:
    1. Which factor causes the problem?
    2. What exactly a reboot achieves that solves the malfunction?
    3. How can I solve the problem by acting similarly to a reboot but without rebooting the device?
    Any ideas??
    Device: Motorola Atrix 4G
    Custom Rom: Android 2.3.7 Cyanogenmod MROM -1-0.20130113-olympus
    01-11-2014 10:54 AM
  2. srkmagnus's Avatar
    Can you reproduce the same issue with a stock ROM? If not, then it's likely the ROM and or the network. Check to make sure there are no issues with the ROM as reported by the developer or users. If not, then it could be a network problem, which you'll have to contact the carrier.
    Golfdriver97 likes this.
    01-13-2014 09:54 AM
  3. Golfdriver97's Avatar
    When I went from Stock Samsung to Slim, I noticed a drop in cell quality. Everything I did had no effect, including flashing older modems. I took it as a nature of the beast as I wasn't totally without a signal. The same may be for you as well.
    01-13-2014 10:14 AM
  4. stelios85's Avatar
    It was finally a DNS issue.
    01-19-2014 11:11 AM
  1. No, I don't want Visual Voice Mail. How to stop pop up?
    By N2myN2 in forum Verizon Galaxy Note 2
    Last Post: 04-06-2016, 02:11 PM
  2. Please Help! Can't Get Galaxy S4 Keyboards To Remember Words Now
    By amocksun in forum General Help and How To
    Last Post: 01-03-2015, 01:34 PM
  3. Trouble getting Google Chromecast to connect to second TV
    By cmualex in forum Google Chromecast
    Last Post: 10-26-2014, 04:02 PM
  4. How to get rid of the Safety Care app?
    By Roy Berntsen in forum LG G2
    Last Post: 07-07-2014, 05:37 AM
  5. Copy stock 4.3 email app to another device?
    By Skip Tannen in forum Sprint Galaxy S III
    Last Post: 01-12-2014, 10:59 AM
