Results 1 to 21 of 21
Like Tree4Likes
  • 1 Post By UJ95x
  • 1 Post By wizzrah
  • 2 Post By Golfdriver97
    Default memory problem
    hi can i ask how can i put back of my tablet internal istorage becuase before o have a lot of memory and now it became 00.0mb i already reboot wipe all data but not once or twice now i cannot download any apps yes im success with but the problem is i lost all of internal memory can anyone help me about my problem
  2. #2
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    Default Re: memory problem
    Quote Originally Posted by Weng Omaps View Post
    So you wiped the storage, but it still says that there's no room left?
    yes i've done so many time's and still nothing happen good still 00.0mb
  4. #4
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    Try downloading ES File Explorer: https://play.google.com/store/apps/d...gs.android.pop
    See if there is anything in your phone still that is taking up space.
    can u give me info? first its rooted and i unroot and i restart then the out come is factory defult then the internal memory is gone
    tnx and here some the total is 00.0mb but at the lower it has a apps about 43mb
  7. #7
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    Could you clarify more on what you need more info on? You just install the file explorer, start the app, and then view any folders to see if they have any content in them.
  8. #8
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    You say you're rooted. Do you have a custom recovery as well?
    Sent from my Galaxy S4 running SlimKat 4.4.2
    no i dont have i was to download it but i think i have to unroot first i used z4 root
  10. Thread Author  Thread Author    #10
    can i bring it back? i cant download anything its say's error downloadinh no more internal storage space
  11. Thread Author  Thread Author    #11
    sir i cant download it say's always error downloading no more internal storage space
  12. Thread Author  Thread Author    #12
    i cant install anything because of no internal storage
  13. #13
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    You can install a custom recovery with root. With that you can wipe the internal storage
  14. Thread Author  Thread Author    #14
    how? i try to insall a small size but it still not work always error i reboot again and still 00.0 mb
  15. Thread Author  Thread Author    #15
    even root checker i cannot download from play store because of 00.0 mb of internal storage
  16. #16
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Try connecting to your PC and see what you can delete. Then download ES file explorer once you have enough space and use that to delete any app data that you don't need
    wizzrah likes this.
  17. #17
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    Also to add to UJ95x's suggestion about connecting it to a PC, if there is nothing there, it might be a software bug...
    Sent from my AT&T One X running CodefireX ROM Android Version 4.4.
    UJ95x likes this.
  18. #18
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,676 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    I would suggest deleting some apps, text messages, pics, to generate more room, to allow some of the downloads
    From a Sprint Moto X using AC Forums app
    UJ95x and wizzrah like this.
  19. Thread Author  Thread Author    #19
    Default
    tnx for all of your suggest i hope my tab will be ok
  20. Thread Author  Thread Author    #20
    i'll try to see whats wrong maybe its a bug thays make my internalstorage 00.0 mb
  21. #21
  1. Multi Window Problem
    By aweciti in forum Verizon Samsung Galaxy Note 3
    Last Post: 02-19-2014, 04:16 PM
  2. Replies: 2
    Last Post: 02-18-2014, 10:58 PM
  3. Charging issues- Clearing Cache re leaved problem for only 8 days.
    By kelleygirlmma in forum Samsung Galaxy Tab
    Last Post: 02-18-2014, 09:31 PM
  4. Note 10.1 2014 edition email problem
    By Roger65 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 02-18-2014, 08:32 PM
  5. wifi and bluetooth problem
    By galaxyman2010 in forum Samsung Galaxy S4
    Last Post: 02-18-2014, 06:27 PM
