Hi everyone, good forum. I have been running around trying to find a solution to this problem but everything I have tried so far has not worked. Hoping you can help, here is the info:
Samsung Galaxy i9100 aka SG2
Unlocked
Not rooted
No custom ROMS or any schenanigans
Android 2.3.5 Gingerbread
The phone seems to work fine as a device in that it takes pictures, I can view them, I can use my notepad, read the BBC news, check the weather, Gmail and such. I met a friend and tried to enter the contact on my phone and it froze, then generated "the process android.process.acore has stopped unexpectedly. Please try again".
So, while I can tap in a number and call, I can't add it as a new contact whatever way I try. Also now I scroll through my contacts and look at the names, but when I tap a name to open, it wont show me any info at all. It just hangs and then gives me the error message.
I have tried:
- Turning off and on again ---> NO
- Backing up the contacts, deleting contacts, turn off/on, restore contacts ---> NO
- Backing up the contacts, deleting contacts, settings-applications-running services-contacts-clear data ---> NO
- Backing up the contacts, deleting contacts, settings-applications-running services-contacts storage-clear data ---> NO
- Clear contacts data AND clear contacts storage data ---> NO
- Removing Outlook, BBC Weather, Anagram game (the only game on the device) ---> NO
- Entering recovery mode and clearing the cache ---> NO
- Resetting ProcessTW ---> NO
- Stopping Gmail, Skype, Viber, Whatsapp sync ---> NO
- Talking politely to my phone and asking it to be nice to me ---> NO
- Yelling obscenities at it ---> NO
As far as I can see, I have factory reset as the last option, which seems drastic. I'm not even sure of the reset passwords or where the phone documents are. Also, I don't want to brick the device trying to flash the memory, even though it has served me well for very close to 3 years, unless that is also the last option.
If anyone has any ideas, please let me know step by step. I have been all over the net looking for ideas and none have worked for me. I saw somewhere that facebook caused this issue with many, but I don't use facebook and don't have the app on my phone. I have also NOT recently installed any new app for some time. Probably the last app I installed was the anagram app, which was about 2 weeks ago. Having removed it, the error continues.
To be clear, the message does NOT repeatedly pop up no matter what I do with the phone. The error message ONLY pops up when I try to add a contact or view contact information.
I have to go out for about an hour or so, but I will be leaving this open on my computer to respond to any kind soul willing to help diagnose this problem.
Thanks guys.
Unlocked
Not rooted
I have tried:
Thanks guys.
