Results 1 to 2 of 2
    Default rooted nookcolor plz help having problems
    I just purchased a nookk color and am rooting honeycomb on it...i got to the last step and put the sd card in my nook color to have it boot off of it...it began to boot, then i got a loading screen with a skull and crossbone on each side of the word loading spelled in all capitals
  2. #2
    Default Re: rooted nookcolor plz help having problems
    That boot graphic is usually what you see when loading clockworkmod. What guide are you using?
