Results 1 to 11 of 11
- 01-21-2012, 08:26 PM
Thread Author #1
WiFi Xoom freeze issue after ICS upgrade
It seems to be getting better, but my Xoom freezes for, what seems to be, no reason at all. I don't know what's causing it. Sometime it's on a home screen, after I've checked my email, or just after sitting for a while. I basically have just stopped using it since the upgrade(Thursday), because of its unreliability.
Is this just mine or are other people having problems with this as well?Last edited by rng1977; 01-21-2012 at 08:34 PM.
- 01-22-2012, 05:22 PM #2
Re: WiFi Xoom freeze issue after ICS upgrade
I've been having the same problem. Usually it happens when I switch from an app back to the main screen, but I've also seen it happen when I've tried to drop an app icon into place, or uninstall an app. Normally I've just had to wait (less than a minute) for it to reboot, but the last couple of times I've had to a hard re-boot.
I've only had my Xoom since Christmas (2011), and I'm wondering if there's an easy way to revert back to Honeycomb. - 01-22-2012, 07:13 PM #3
- 01-27-2012, 07:16 PM #4
- 01-29-2012, 05:57 AM #5
- 01-31-2012, 03:24 PM #6
- 02-07-2012, 10:42 AM #7
Since my Xoom downloaded the ICS upgrade, I have had to deal with frequent freezups, often necessitating forced reboots
I performed a complete factory reinstall, hoping it would get me back to Honeycomb, but the reinstall results in installaton of ICS.
I have not used live wallpaper. Wish I had a way to get back to honeycomb.
- 02-27-2012, 02:12 AM #8
- 02-27-2012, 09:02 PM #9
- 03-01-2012, 04:04 PM #10
Mine is a bit wonky at times too. It was pretty stable on Honeycomb, but it 'feels' like the battery drains faster too on ICS. ICS looks amazing on the tablet, I just wish it didn't get bogged down from time-to-time. Hopefully there's an update that fixes this.
- 06-04-2012, 11:36 AM #11
Reply
