Help: Android OS Corrupted or Bug ?
Hi, I'm a newbie and I would like to ask you questions about my problem and hopefully you could help me.
My tablet can't open, it always sticks on the loading screen. I think my tablet is corrupted, can anyone help me how to reset my android tablet ?
It looks like this, I waited for how many hours but it won't reboot, please I need help .
[Only registered and activated users can see links. Click Here To Register...]
Re: Help: Android OS Corrupted or Bug ?
You offer no info on model or make of tablet so its kimd of tough. But in general a reset usually entails holding down the power and volume buttons at same time until shutdown begins.
If that doesnt work go online with a pc to your model site and check their support.
Simple fixes sometimes happen if you simply unplug and replug the charger and or battery if possible.
Sent from my SGH-T989 using Android Central Forums
My tablet model is O+ 9.7 Pad .
Specifications:
+ FACTORS
Powerful Android 4.0
9.7" widescreen multi-touch display with IPS technology, better viewing on all angles! 1024 x 768 pixel resolution at 132 pixels per inch
1.2 GHz Processor.
Dual camera! Do video calls with front camera, 3MP back camera
FB, Twitter anytime, anywhere, via Wifi or USB
8000mAh battery for up to 4 movies!
Plug and play movies, videos with memory card slot, USB Port
Maximize HDMI. Just link to TV!
16GB Internal Memory
Connect
WIFI
USB Modem
HDMI
Memory Card Slot
USB Port
Look
9.7" IPS Screen
1024x768 Resolution
Capacitive
234 x 186 x 9.9mm
600g
Capture
3 Mega Pixel Camera
Front Camera
Video player
Video Recorder for front and back camera
Listen
Music Player: Mp3, Mp4
Side Volume Controls
3.5mm Headset
Audio Recorder
Speaker
Innovate
Android 4.0
1.2 GHz processor
Internal memory of 16GB
Connect
8000mAh Battery
Charger Plug
USB Cord
3.5mm headset with Mic
I can't find any solutions so I preferred to ask it here . I can't boot the tablet, it always freezes and keeps on loading. Any other solutions ?
