Android tablet seems stuck in diagnostic mode
Hi
I am new to android and my sons Kurio 7 device seems stuck in diagnostic mode.
When it starts it boots fine but I have what look like system Diagnostic messages on right of screen and the x and y coordinates on the screen are displayed
Anyone any ideas
Thanks
Re: Android tablet seems stuck in diagnostic mode
it sounds like you have some of the developer options turned on. i'm not familiar with that tablet but if it was an HTC phone, then the option to turn off would be called "pointer location". you should be able to go into the settings and find something like, if not exactly, developer options. hope this helps
