Results 1 to 1 of 1
- 02-12-2013, 10:09 PM
Thread Author #1
Sd Card issues of many.
the problem happen from yesterday and i only had this sd card since dec when i got my phone.
1. first time it happens i format it though it must be some error.
2. once format was working fine and i started to download from google play again.. of of then
3. while downloading most of the apps back on sd card and moving few which was saved on internal drive.
4. it freeze up but return back.
5. then i when i wanted to add more i check the storage it seems my sc card was showing this -1.00b space and apps 300mb????
6. again and again it wanted to format but i want to save these apps rather then downloading each of them again.
7. i connected to desktop but once connected it asked this card to be formated.
8. i tried with the repartition software but was showing it as bad.
9. now after few shut down and finally show the free space i have but would not open any program or would not go to apps utility where i can remove them from.
10. also it is slow now.
what too do.
Did FRF72 or FRF83 fix the 32GB SD card issue
By tjp888 in forum Google / HTC Nexus OneReplies: 2Last Post: 06-28-2010, 10:43 AM -
Solution To The SD Card Issue
By showmrock in forum HTC EVO 4GReplies: 3Last Post: 06-03-2010, 09:59 AM -
evo sd card issues?
By blupit30 in forum HTC EVO 4GReplies: 14Last Post: 06-02-2010, 07:09 PM -
SD card issue
By MNTwinsFan in forum General Help and How ToReplies: 4Last Post: 05-01-2010, 12:40 AM -
SD card issues
By vbsoulpole in forum Software Development and HackingReplies: 1Last Post: 02-07-2010, 03:04 AM
Reply
