Android 4.04 does not encrypt.
Hi! I have a cheap Irulu 7" tablet with Ice Cream Sandwich and Android 4.04.
I've successfully used Truecrypt to create, mount, open, and dismount files and folders on a usb flash drive and memory card on my Windows Vista computer. On my tablet I've used Trucrypt Portable, Cryptonite, and Ed's Lite to attempt to open those volumes or create new volumes on the same HP usb flash drive... I've so far had no success creating volumes with these apps. When I try any of those apps to open a volume on the Android from that same usb flash drive I can see the name of the file, but get a msg. similar to "file path not found."
Could somone tell me what I should do, or is my Android version not able to do this stuff? Thanks!
