Dead image.
Sent from my HTC6435LVW using Android Central Forums
I was able to see it in your own quote....strange. https://docs.google.com/document/d/1R8prEaRNlzlgLTpOYlXf0G-_1chzfaa2VfFPpmrkVYM/edit
Dead image.
I guess a good place to start is asking this. Have you attempted rooting this phone or are you running a custom ROM? Were you able to boot into recovery mode, and then it showed you the android with the red exclamation point?
What I've gathered is if the phone is not rooted, there is no recovery to boot into, hence the red triangle.
Yeah. My phone isn't rooted.
May not be the best solution, but have you tried a factory reboot, since booting into recovery is a no go?
To enter Recovery Mode, you press and hold the Volume Down + Power buttons together until the screen powers on. Use the volume button to navigate to recovery and the power button to select it.
How did you unroot?
I don't think it was ever rooted...
I think clearing the cache partition might work. But all data on the phone (not sd) will be wiped.
What do I select?
All right, I'm on the case, now to read this thread and help out.
TL/DR: Monitoring this bread.
Sent from my ASUS Transformer Pad TF300T using Android Central Forums
What do I select?
Okay, so after reading this, I have the way to fix this (I hope)!
So, pull out the battery or shut down the device.
From there, place battery back in if you took it out.
Hold down Volume Down and hold down Power until you boot into the HBOOT menu (The screen with info at the top and 3 skateboarding Androids at the bottom).
Select the RECOVERY option using the Volume buttons.
Your phone will show the HTC EVO 4G screen, then you'll see a black screen with a phone laying down with green arrows. Wait until it turns into a red triangle with an exclamation point inside the triangle and from there, hold down the Volume Up and then press the Power button. You should now see a small list. Congrats, you're in the stock recovery!
From there, select "Wipe /cache", and if it has the option too, "wipe /dalvick-cache".
Reboot the device. If all is successful, congrats, your phone works again!
And yes, lack of system memory will cause apps to Force Close. I had a Motorola Flipside that only allowed 70 MB for installing apps! And technically, I only had 55 MB due to low storage issues. That caused a lot of apps to crash, and ultimately, the phone.
Hope this helps.
A few questions for you:
1. Is it just the full memory that made her phone go nuts?
2. Steps to take to stop this from happening again; i.e. more frequent rebooting?
