OperationA7X
Oh, and clearing the /cache through recovery won't factory reset the device, only if you select FACTORY RESET in the HBOOT menu or when you're in the recovery and wipe /data.
Just wiping /cache won't factory reset the device.
Sent from my HTC Vivid BoRKed using Android Central Forums
