1. trigunesq's Avatar
    So today I attempted to swap my battery for a full charge and It go stuck in a loop. The screen would show a large battery icon that also indicated how much battery was left and then simply power off after a few seconds and then would power back on again. It does this as soon as i put any battery in the phone. i dont even need to press any buttons it simply goes through this loop as soon as i power it on. I can get it to go to the home screen and power the phone normally by holding the power button in between loops but the red LED notification light is always on. never shuts off. I tried using lightflow and that barley works. it will shut the light off but it will turn back on once i get any notification and stay on. any help would be appreciated. I know i could reset my phone to factory but lets be honest if i can avoid that headache tonight that would be great.
    I have a sprint galaxy s2
    i was at the pool and i had to pull the battery due to a freeze and it started doing this. im leaving it out to dry in the offchance that it got too hot or moist
    07-09-2013 05:06 PM
  2. Deanig_12's Avatar
    :/ i did this with my s2 and i hyave to factory rest it and clean os then my phone worked like a charm hope this helps
    07-14-2013 05:13 AM
  1. NLPwakelock running my battery down?
    By justmikey in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-18-2015, 11:57 AM
  2. Firefox beta and bookmarks
    By buryman in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-10-2013, 03:48 AM
  3. Firefox beta and bookmarks
    By buryman in forum Google Play Store
    Last Post: 07-09-2013, 04:48 PM
  4. SkullCandy 'The Fix' and others with Nexus 4
    By DiNZi in forum Nexus 4 Accessories
    Last Post: 07-09-2013, 04:24 PM
  5. Replies: 0
    Last Post: 07-09-2013, 03:58 PM
