Results 1 to 6 of 6
Like Tree3Likes
  • 2 Post By B. Diddy
  • 1 Post By Golfdriver97
    Kyle Jensen's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Plugged tablet into wrong charger
    I plugged my tablet- A Dopo M975 into a higher output charger and it wont turn on and shows lines horizontally and I need help with it
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    78,012 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Plugged tablet into wrong charger
    Welcome to Android Central! How long was your tablet plugged in with the wrong charger? Try plugging it in with the correct charger and letting it sit overnight (in case the battery discharged somehow), then press and hold the power button for a good 20-30 seconds. If you get nothing, it's probably fried. Since the brand is unrecognizable to me, I'm guessing it may not be worthwhile sending it back for repair, because (a) it probably won't be covered under warranty if they can tell you used the wrong charger, and (b) if you have to pay for the repair, it might cost about as much as the tablet itself.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The tablet is made by double power tech Double Power Technology Inc.-DOPO 9? Internet Tablet M975(Android 4.0 OS) and the tablet, when plugged into the charger gets hot after 5 minutes and i have tried the usb as well. I have a warranty for it.
  4. #4
    B. Diddy's Avatar
    Posts
    Global Posts
    78,012 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Is it getting hot after 5 minutes using the correct charger? How hot? It shouldn't get unbearably hot--if it does, something's wrong. It's good that you have a warranty, but you might run into problems if they determine that any circuitry was damaged due to improper charging. Hopefully they won't be able to tell ...
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hopefully and yes it does get warm after a minute and starts to burn my hand after 5 minutes. I dont know what would cause it and I have left it plugged in for 2 hours (not a good choice) and i touched it and it gave me a blister.
  6. #6
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,082 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Quote Originally Posted by Kyle Jensen View Post
    I would be contacting the manufacturer. No matter what, that isn't good at all.
    Kyle Jensen likes this.
  1. Anybody move from a 10' tablet too the Nexus 7?
    By msavic6 in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-26-2013, 02:52 PM
  2. Guide to Install Cerberus.zip into phone
    By Doog Lingo in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 08-21-2013, 10:30 PM
  3. My tablet when I turned it on
    By Chillidog66 in forum Acer Iconia A500
    Last Post: 08-21-2013, 08:06 PM
  4. My First Tablet: Mini Review, and 1 Question
    By DroidFox in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-21-2013, 08:42 AM
  5. Cannot sync/drag & drop anything to Nexus 7 tablet (2012)
    By forwardthrall in forum Google Nexus 7 Tablet (2012)
    Last Post: 08-21-2013, 07:52 AM
