1. ron issac's Avatar
    I feel lik my battery meter n nexus 4 is not correct. For a moment it shows 70% and then it shuts down. The phone gets on only when I put it for charging starting from 1%...and after 5 mins of charging if I switch off my phone the battery shows 80%.. ND the cycle literally repeats itself..can anyone suggest if this is a software or hardware problem.. I HV no clue what's happnin...
    08-25-2013 06:42 PM
  2. srkmagnus's Avatar
    That type of battery issue is typically associated with a bad battery. Since the battery is not replaceable it's probably easier for them to replace the device.
  3. Chewch99's Avatar
    Same thing happened to me. After researching everything I could online, no one seems to know a fix for the issue. I thought maybe it was related to kit kat updates and went down to 4.3, did a factory reset, etc. Nothing worked. Contacted Google play store support and they issued a return under waranty for a replacement phone. After I told them the issue, they went right into sending me a new phone, no troubleshooting or anything. That leads me to believe they know it's a issue and there is no software fix so it has to be some kind of sensor, battery, or hardware issue.
    03-24-2014 12:12 AM
  4. srkmagnus's Avatar
    03-28-2014 06:53 PM
  1. Straight Talk AT&T APN settings w/ the Nexus 4
    By ehaus81 in forum Other US Carriers
    Last Post: 01-28-2014, 08:25 AM
  2. A few days in, how does everyone like their X?
    By Jtshurtleff in forum Moto X (2013)
    Last Post: 09-05-2013, 03:08 AM
  3. Replies: 2
    Last Post: 09-03-2013, 04:48 PM
  4. Update broke my Nexus 7 (2013)
    By appmy in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-26-2013, 08:15 PM
  5. Anyone also have a Nexus 4 ?
    By pseudoware in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-25-2013, 04:20 PM
