1. MeganND's Avatar
    I've only had the phone a few months but am starting to have a few issues:
    * Notification screen, I slide down and screen is black. I usually have to hit the lock button on and off for the notifications to show up (this just started in the last few days).
    * Phone internal GPS or whatever it is keeps putting my location to cities I'm not in (cities almost 200 miles away). Same ones all the time but obviously not where I'm located. This will happen when I try to use a weather app or even on Facebook. Not a huge issue obviously but weird.
    Anybody have any ideas - especially on the notification screen issue?
    Thanks!
    08-29-2013 12:03 PM
  2. Scott Kenyon's Avatar
    Sometimes the worst option is the best option. I don't have any good reason for this occurrence other than a software issue that a reset may solve. Sorry for the bad news, Megan!
  3. Scott Kenyon's Avatar
    Try to factory reset the device for the notification problem. I'm not really sure what could be causing it other than a software glitch that a reset may rectify. As far as your location issue, I'll tell you something I experienced. I used to live near Poughkeepsie, NY, and work in Danbury, CT. When I was at home on wifi, everything was normal. I got to work one day and my location said I was in Vancouver, Nevada. Who even knew there was a Vancouver, Nevada?! When I turned on the actual GPS radio, everything was sort of crazy with my location switching back and forth between Vancouver and Danbury. Anyway, I let it go for a few days thinking it was something silly. The problem persisted so I posted my issue on a forum. An intelligent individual told me it was AT&T's cell towers causing the issue. Sure enough, they were doing maintenance on the towers, and a few weeks later my location reverted to Danbury. I thought it was my phone and almost got it replaced! Call your carrier and ask them if they're doing any work to the cell towers in your area. If so, that may be the problem.
    08-29-2013 12:14 PM
  4. MeganND's Avatar
    Eeek I was hoping to avoid a hard reset. The location problem has been going on since I got the phone but I did hear that towers were being updated in my area so maybe that's it.
    Scott Kenyon likes this.
    08-29-2013 01:00 PM
  5. Scott Kenyon's Avatar
    08-29-2013 01:07 PM
  6. samhamforash's Avatar
    Was having the same problems. But flashed a custom Rom from android area 51 and it's like a new phone.
    mumbum Mukul likes this.
    08-29-2013 01:41 PM
  7. Scott Kenyon's Avatar
    Yeah, a rom will solve this as well, if you're daring enough.
    08-29-2013 01:48 PM
  8. bccric's Avatar
    I had the same problem w gps. I too flashed the arearom but i still have the problem with several apps that locate me constantly 100 miles north right down to a street addess that i have never been to.
    Sent from my SCH-S738C using AC Forums mobile app
    09-08-2013 04:24 PM
  9. MeganND's Avatar
    Well, I broke down and did a factory reset. Was able to connect to network last night after this and now this morning, can't connect to anything. Every app is stating that that it can't connect and to "check your network" but mobile access is on, I have 3 to 4 bars of 3G. Getting really irritated...
    09-24-2013 08:26 AM
  10. MeganND's Avatar
    ARGH... Hard reset didn't fix location issue or notification issue and of course now my connection to network keeps dropping.
    09-24-2013 09:26 AM
  11. wham6988's Avatar
    Can anyone tell me how my boyfriend is reading my text messages on my rooted samsung galaxy century after i delete them
    01-04-2014 01:52 PM
  12. Taylor Mcdaniels's Avatar
    How can a 4.0.4 Android centra get emojis?
    05-17-2014 08:07 PM
  1. My Galaxy Tab 3 "rings" from time to time
    By Denis54 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-11-2016, 12:54 AM
  2. Details from a Galaxy Nexus user that upgraded to the Maxx
    By xweb10 in forum Motorola Droid MAXX
    Last Post: 08-30-2013, 11:53 AM
  3. Slight Screen Lift Problem
    By daaarn in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-29-2013, 04:24 PM
  4. Replies: 1
    Last Post: 08-29-2013, 12:29 PM
  5. APK Installation problem
    By Vishnu Sai in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-29-2013, 11:13 AM
