1. jbz360's Avatar
    so i have the wifi tether apk it works fine but after 42mb it stops woking and no wifi is coming out of device any suggestions
    09-22-2013 03:10 AM
  2. Haalcyon's Avatar
    Welcome to Android Central, it's great to have you here. I'm no expert on tethering but that sounds nefariously like a carrier limitation, but that could just be my tin-foil hat at play.
    09-22-2013 05:52 AM
  3. Distant Deviant's Avatar
    Some apps only allow so much then they want you to go pro to keep using it, if not its your phone or your carrier figured you out.
    "Our business is life itself."
    -Umbrella Corp.
    srkmagnus likes this.
    09-26-2013 03:57 PM
  4. Distant Deviant's Avatar
    Like pdanet+ app once you go pro you can use unlimited tethering and the data that you use via computer appears as phone data usage not comp usage, making you hidden from your carrier that you are tethering.
    -Umbrella Corp.
    09-26-2013 04:00 PM
  5. srkmagnus's Avatar
    Have you taken a look at other tether apps available in the Play Store? I agree that it's a limitation with the App wanting a purchase or some sort of paid upgrade.
    09-27-2013 11:38 PM
  1. Replies: 9
    Last Post: 02-10-2014, 05:09 PM
  2. Taking the Note 3 after holding off on the Note 2
    By Beantown Bashers in forum Samsung Galaxy Note 3
    Last Post: 09-23-2013, 07:45 AM
  3. Wifi disabled via provider help
    By Tonia Willman in forum General News & Discussion
    Last Post: 09-23-2013, 01:19 AM
  4. Nearby Devices connecting
    By Jack Edmunds in forum Samsung Galaxy Tab 3
    Last Post: 09-21-2013, 05:13 PM
