hi Evrey one >
at first sorry for my english
my tablet is ( i-life wtab 704) android 4.0.4
today i tried to root my tablet with z4root .
After that i rebooted and everything gone as like as the( factory rest )
so i began to install apps but the system give me a Message said (there is no enough memory)
i checked the storage i found the internal storage zero
then i rebooted it after that . Everything gone !!!!!!
but i noticed something .....
before trying to root my tablet ..i didnt have a recovery mode on my tablet ....when i try to press the 3 buttons (power + volume up + volume down) it didnt refer me to the recovery mode but keeps the screen stand still then reboot ( because its locked i think so)
but after use z4root ...when i do factory reset it shutdown then refer me to the recovery mode mentioning that i didnt install a recovery mode
in the recovery mode
...i made a wipe/factory reset...and made a cache wipe
but nothing happened
and The problem remains as it is
So please.... help me
