1. SkateTrash420's Avatar
    i have a samsung galaxy Centura and was wondering if anyone knew how to decrypt the init on the root of the device?...it is an elf file....
    02-07-2014 08:46 AM
  2. Paul627g's Avatar
    Hello,
    I've dabbled some in ROMs and various ins and outs of working with Android and the Android system but this one I'm a little foggy on.
    Could you please provide a little more information as to what exactly your trying to accomplish and hopefully someone with a little more knowledge can help you out.
    Good luck!
    Paul
    Moderator Team Leader @ Android Central.
    02-07-2014 08:52 AM
  3. SkateTrash420's Avatar
    id like to tie in some mountpoints.... i was trying to do it through proc/mounts file however i cant edit it with romtoolbox pro because it wont save.... nor can i push a modified one because i get permission denied even though my system is mounted RW and givin chmod 0777 permissions
    02-07-2014 09:11 AM
  4. SkateTrash420's Avatar
    Hello,
    Good luck!
    Paul
    Here a copy of my. init....its encoded with some language, is there any way to decrypt it? it lloks like its an elf file as far as i can tell....is it possible to make it into a self file then recompile back to elf?
    02-09-2014 10:35 PM
  1. Jiake JK-10 Malware issue, want to root. Please help
    By geoffist in forum Android Security Talk
    Last Post: 03-24-2016, 09:54 AM
  2. rooted kyocera hydro C5170 update help please
    By XanaxMaster in forum Android 4.0 Ice Cream Sandwich
    Last Post: 03-03-2014, 07:24 PM
  3. Getting a nexus 5 - need help
    By MissPrettyKitty in forum Google Nexus 5
    Last Post: 02-07-2014, 03:25 PM
  4. [Q] Help Needed For BusyBox
    By woliw in forum General Help and How To
    Last Post: 02-07-2014, 05:55 AM
  5. Centura help
    By SkateTrash420 in forum Android 4.0 Ice Cream Sandwich
    Last Post: 02-06-2014, 10:27 PM
