Results 1 to 3 of 3
    RoundTwo's Avatar
    Posts
    Global Posts
    3 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Storage problem on 4.0.3 please help
    I have a Acer iconia a200 and I keep having to reset it because after about a day of use I keep getting "low disk space" etc I cannot download apps I got one or two at the moment and in settings under apps it says 5.3 or so gb used. It makes no sense the numbers don't add up.
    If I go to storage in settings where it says "downloads" it calculated about 4.7 gb. When I click, it says "no downloads". So I'm so confused why am I out of space when i downloaded almost nothing.
    The only possible explanation is I have downloaded or played/streamed tv shows. If thats the case and there is 4.7 gb in downloads then why does it says "no downloads" ?
    Sorry for the bad grammar etc. I'm just up till 630am here and typing without a keyboard any help would be great again Im using a version 4.0.3 most up to date software for this model Acer iconia a200 8gb storage. Almost nothing is on this but I keep running out of space without a way to clear it I have no idea why.
    Apologize if this was hard to read. I am continuing to try and fix this
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,764 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Storage problem on 4.0.3 please help
    Quote Originally Posted by RoundTwo View Post
    Welcome to the forums!
    Storage for downloads and Storage for applications are two different things. You must have a storage issue with the available memory for applications. The temporary fix is to go into Settings > Applications > Sort by Size. Clear the cache for the top apps that are consuming the most memory. Again, this is a temporary fix as you'll have the same problem when available storage runs out. I would suggest deleting any unused apps that are consuming lots of memory.
  3. #3
    teo17's Avatar
    Posts
    Global Posts
    17 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try CleanMaster. It can delete cache, detect large files and show a list of apps arranged by size or name.
  1. Samsung Galaxy S3 on 4.3 - enabling mass storage?
    By pinkpanther3610 in forum Samsung Galaxy S3
    Last Post: 10-09-2015, 12:37 PM
  2. G Mail on Tab 3 8.0
    By 13oscar in forum Samsung Galaxy Tab 3
    Last Post: 04-07-2014, 01:30 PM
  3. GPE roms on non-GPE devices
    By Marco Ciccone in forum Android 4.4 KitKat
    Last Post: 04-07-2014, 12:24 PM
  4. BOGO on Verizon Galaxy S5 pre-orders
    By buzzy3970 in forum Samsung Galaxy S5
    Last Post: 04-05-2014, 11:59 PM
  5. HELP please - Chromebox problem
    By ziffos in forum Chrome OS
    Last Post: 04-05-2014, 09:23 AM
