1. renshiki's Avatar
    I have this sound quality problem whenever I listen to music loud it sounds fuzzy and distorted please help me how to fix it! Ideatab A210A-H verson 4.0.3
    06-01-2014 04:53 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is it just the music that sounds bad, or are all sounds fuzzy? If the latter, then it's probably a bad or blown speaker.
    If it's just the music that sounds bad, which music app are you using?
    06-01-2014 05:10 PM
  3. renshiki's Avatar
    It naturaly has low sound when listening to music,even when the sound is full,it has no bass can't control it, when I turn on the equalizer,it sounds distorted my sister's android phone has great sound quality but my tablet has low sound quality it can't control bass in headphones.I don't use an app.
    06-02-2014 02:09 AM
  4. B. Diddy's Avatar
    Ok, but my question was if all sound is bad, or just music. If all sound (including ringtones, notification tones, game sound effects, etc.) is bad, then your device may have faulty firmware or sound processing software. If it's just the music, then it may have to do with the music app that you're using to play. I'm not sure what you mean when you say you don't use an app--if you're listening to music on your device, you're using some kind of app to listen to that music (like Google Play Music, for example).
    06-02-2014 02:15 AM
  5. renshiki's Avatar
    All the sounds are fine,I use the music player that is already in it and I still can't hear the bass of the music,I think it's speakers can't control bass in headphones.
    06-02-2014 10:09 AM
  6. B. Diddy's Avatar
    Go to Settings>Sound and see if there is an Equalizer setting there. Or open Google Play Music, swipe in from the left, and tap Settings, and see if there is an Equalizer setting there. Can you adjust the sound to your liking with it? If not, then how is the sound with the Equalizer turned off? It may be that your device doesn't support Equalizer settings very well, and it's the Equalizer itself that is distorting the sound.
    06-02-2014 11:31 AM
  7. renshiki's Avatar
    thanks,it was actually the equalizer distorting the sound,my tablet normaly has low sound it's fixed .
    B. Diddy likes this.
    06-02-2014 01:01 PM
  1. I have just 1 question....
    By Larzukzek in forum Android 4.4 KitKat
    Last Post: 06-03-2014, 12:34 AM
  2. Does an Unlocked LG Optimus G E970 work on MetroPCS 4G LTE?
    By FiretoFlames in forum LG Optimus G
    Last Post: 06-02-2014, 02:15 AM
  3. Replies: 1
    Last Post: 05-31-2014, 11:27 PM
  4. No internet connection despite having lte
    By valapsp in forum Android 4.4 KitKat
    Last Post: 05-31-2014, 11:16 PM
  5. Help...I think I killed it for Good
    By waxfetish in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-31-2014, 09:41 PM
