Results 1 to 7 of 7
    Default why does my tablet's sound get stuck while shutting down
    My tablet's sound gets stuck when I shut it down,what could be the problem?
  2. #2
    Default Re: why does my tablet's sound get stuck while shutting down
    Sorry, but what do you mean by that? Do you mean that there's a prolonged sound while the the tablet is shutting down? Also, please let us know which tablet you're using.
    No,it actually lags and shuts down.
    It's A2107A-h ,it never got stuck when I first bought it.
  5. #5
    I'm still not understanding fully. Are you actually trying to shut it down, and it just freezes? Or does it lag while you're using the device, and then shut down unexpectedly?
    No, its sound gets stuck a little and then it shuts down
  7. #7
    So you're saying that you'll be using your tablet, then suddenly you'll hear one of the system sounds for a prolonged period of time, then the device shuts off on its own. Right?
    You might need to do a full factory reset. Go to Settings>Backup & Reset>Factory Data Reset. It will wipe your tablet clean, so backup your data first.
  1. Anybody get the 4.4.3 update yet?
    By longtime44 in forum Google Nexus 5
    Last Post: 06-12-2014, 04:44 PM
  2. Replies: 3
    Last Post: 06-04-2014, 11:24 AM
  3. forwarding text messages from my s4 to note 8
    By Jilly12 in forum General Help and How To
    Last Post: 06-04-2014, 01:39 AM
  4. my samsung galaxy s4's sound no longer works after I insert SD card
    By bai216 in forum General Help and How To
    Last Post: 06-04-2014, 01:12 AM
  5. 4.1 'sees' my USB drive but 4.2 doesn't
    By varimac in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-03-2014, 11:42 PM
