Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By meyerweb
    Diego Retaggi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery drain samsung galaxy s3
    is it normal? i was looking around the web and 65% seems a lot...
    samsung galaxy s3 JB 4.1.2
  2. #2
    Shadowriver's Avatar
    Posts
    Global Posts
    704 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Odp: Battery drain samsung galaxy s3
    Yes, if you got screen on high brigtness wifi can suck in power a lot too
  3. #3
    Spencerdl's Avatar
    Posts
    Global Posts
    32,111 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Odp: Battery drain samsung galaxy s3
    Yes that appears normal, I'm on JellyBean 4.1.1 Verizon SG3. I've become accustom to carrying around an EXTRA battery in my earbud case and my car charger is always available. With todays smartphones and all they can do ....batteries just don't last as long as the old days like with the "dumb" phones
  4. #4
    angryshortguy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery drain samsung galaxy s3
    Since T-Mobile sent an update, my battery has been 50% of what it used to be.
    I need to recharge by 5pm now, before I had 40% left by 10pm when I put it on the charger.
    Nice update tmo...
  5. #5
    meyerweb's Avatar
    Posts
    Global Posts
    10,319 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    To the OP, it would appear you're using the phone, with the screen on, a lot. And yes, the screen will use a lot of battery. But your screen capture would be more useful if you show it from a full charge until just before you have to plug it in. There's no way for us to see what usage was before or after you started to recharge.
    Also, on this screen, tap where it says "Shermo." That will display another screen showing screen-on time.
    Finally, come back to this screen and tap on the graph. That will display a new screen with additional information.
    To AngryShortGuy: I'm not sure what update you're referring to, but the general answer to issues that start after an OS upgrade is to back up your data and do a factory reset. A pain, yes, but it will almost always solve upgrade related issues.
    cjmelerine34 likes this.
  1. Battery Drains when the power is off..
    By cy8ercop in forum Motorola Droid
    Last Post: 08-21-2010, 10:22 AM
  2. Battery drain
    By Snipperdo17 in forum Motorola Droid
    Last Post: 02-02-2010, 05:43 PM
  3. 2.0.1 battery drain?
    By droidweasel in forum Motorola Droid
    Last Post: 01-19-2010, 08:45 PM
  4. battery drain when device is off?
    By sicario666 in forum Motorola Droid
    Last Post: 01-05-2010, 12:40 AM
  5. My battery drained overnight
    By pbrennan42 in forum General Help and How To
    Last Post: 01-02-2010, 03:30 PM
