Results 1 to 3 of 3
    Question samsung galaxy note Viber 3g problem.
    Viber application is not working with 3g, only with wifi, with 3g i can make the call but cant hear or be heard like with wifi, asked the operator and they said its not normal because its working with their own devices properly. i also uninstalled, reinstalled, and also kept the app in mobile memory instead of memory card, can you please help me out?Thanks.
  2. #2
    Viber's Avatar
    Posts
    Global Posts
    566 Global Posts
    Default Re: samsung galaxy note Viber 3g problem.
    Hi there,
    This is Viber's rep. I'n here to assist.
    Sometimes 3G reception could be low, and this is something we cannot control. Naturally this affects Viber's call quality and results in disruptions and broken sound.
    We are continuously trying to improve our handling of 3G, so you can expect better performance as newer versions of Viber are released.
    Please note that having full 3G reception doesn't mean your internet's bandwidth is at the maximum expected. When you see a "full reception bar", it merely means that physically, your phone is covered with the cellular signal.
    When it comes to the bandwidth itself, your connection could still be slow due to various different reasons, such as being in an area with many other users from the same provider, thus congesting the network.
    Meanwhile, WiFi- WiFi calls on Viber should generally be very clear and are free of such disruptions.
  3. #3
    Hi im using samsung galaxy grand gt19082. I face same problem. I totally cant connect while on mobile 3g network. Works fine on wifi. Pls advice, tks
  1. Samsung Galaxy Note 2 USB PC Connection problem
    By moustafasou in forum Verizon Galaxy Note 2
    Last Post: 05-27-2016, 09:04 AM
  2. Problems with Go SMS pro and my Samsung Galaxy Note 2
    By Lunnabelle in forum AT&T Galaxy Note 2
    Last Post: 06-16-2014, 04:52 PM
  3. Samsung galaxy note phone - usb charge flex power port problem
    By mceochaidh in forum Samsung Galaxy Note 2
    Last Post: 02-21-2014, 11:55 PM
  4. samsung galaxy note 2 wallpaper problem
    By Via Chan in forum Samsung Galaxy Note 2
    Last Post: 12-25-2012, 02:03 PM
  5. Replies: 0
    Last Post: 12-16-2012, 03:35 AM
