Hi,
I apologize this is not a pure Android question, but I think the relevant knowledge can be found here.
I tried sending MMS to a friend. I got the message "can not send".
I then tried sending to myself. I first got the same message "can not send".
I then activated MMS (had missed that) by sending a code to the telecom provider. I got a response that MMS had been activated and I restarted device.
I then sent MMS to myself. This time I got the reply "MMS not supported by network." and "server response error". I think that is wrong. I use Swedish telecom "TeliaSonera" and since I can active MMS I am sure it should be there.
I received an MMS (before I activated MMS) and it was received as an Internet link I could visit.
What should I do to be able to send and receive MMS? (I use Galaxy note 2, latest update. To send long SMS I use Handcent as a quick fix since it can be set not to convert to MMS, the stock messaging pgm will ALWAYS convert long SMS to MMS!)
Thanks
ycc
These are the settings indicated by Swedish Telecom (Telia) on their webpage, I don't know if that helps?
Thanks
ycc
(user/pwd are not secret, just the same for all users)Namn: Telia MMS
APN: mms.telia.se
user: mms
pwd: telia
MMSC: http://mmss/
MMS-proxy: 193.209.134.132
MMS-port: 8080 (Fungerar ?ven med Port:80)
MCC: 240
MNC: 01
Verifieringstyp/Autentiseringstyp: PAP
APN-typ: mms
