Results 1 to 4 of 4
    Groudie's Avatar
    Posts
    Global Posts
    5 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Going from stock Eclair to JellyBean Costom ROM on GTi9000T (not like the other problem)
    I've been reading tutorials about how to flash a custom rom. Most, if not all, of the tutorials I have seen so far have suggested that I make a CWM back-up in case of an emergency. My problem is that ROM manager does not support clair any more and I am fairly certain that even if I download an apk file and install it on my phone manually, I will brick my phone.
    I've been using eclair since 2011 and I can't take it any more, honestly. Also, I started learning programming a month ago and plan to start a career in Android app development after I go to uni and graduate from a BA in software engineering. Flashing a rom has become more of a personal challenge for me. If I can do something as "simple" as flash a custom rom then I have no hope of being a developer!
    1.Can I flash my phone without having CWM?
    2.Given the circumstances, is it advisable for me to flash without cwm?
    3. If I can flash without using CWM, will using the factory reset option will brick my phone?
    4. How can I get jellybean on my phone in my predicament?
    I am a total noob to all of this. I am familiar with some terms and their meanings such as root,nandroid etc but that's it. I also don't have the money to get a new phone now. So if a brick it, I'll be stuck using "normal" phone.
    sorry for the typos...need to get to work!
  2. #2
    atrain2324's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    BobZ CM10
    Default Re: Going from stock Eclair to JellyBean Costom ROM on GTi9000T (not like the other problem)
    Quote Originally Posted by Groudie View Post
    1. You need some sort of recovery. Cannot flash without a custom recovery.
    2. See above.
    3. Once you install a custom recovery and then a custom ROM, under no circumstances can you use the phone's built in factory reset. Unless you like bricks.
    4. Your Galaxy S has an official update to Gingerbread. You might want to step up to that first, play around with it a week or two so your existing hardware gets used to the step up. Then after that, you can step up to Jelly Bean 4.1. I believe this may prove useful?
    Groudie's Avatar
    Posts
    Global Posts
    5 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    "unless you like bricks" hahaha... Had a laugh with that one.
    Thanks for the response! It really helped. Last night I updated to Froyo and then Gingerbread 2.3.3
    Now I want to root my phone but it can't find proper rooting instructions for my device. I heard of a program called Gingerroot but apparently OEMs caught on and it no longer works. In fact it soft bricks it. You know of any rooting method I can use?
  4. #4
    gollum18's Avatar
    Posts
    Global Posts
    1,528 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Rooted Mk3
    You could try gingerbreak. Or perhaps convince someone to build you a program that uses zergrush.
    I don't own the device or I would be able to help you. Plus I'm assuming you are running a windows pc. I run Linux so I can't test my applications for windows.
    Sprint GS3 Running TN's Msg and Chubbs
  1. Switching from Stock ICS to AOKP Rom
    By packfanlv in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 06-28-2012, 01:30 PM
  2. going from dark fasciation to a different rom
    By gulfcoastsurf in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 10-07-2011, 09:18 PM
  3. [How To] go from stock Froyo to Gingerbread .595 deodexed
    By Sage_F in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 05-22-2011, 01:13 AM
  4. from Stock Froyo, to CM6, to New ROM
    By maduhbee#AC in forum HTC EVO 4G
    Last Post: 09-26-2010, 06:53 PM
  5. How To- Go from stock to custom 2.1
    By Andrew Ruffolo in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 04-12-2010, 03:39 AM
