Results 1 to 11 of 11
    Default Nexus 4 not connecting to PC after Android 4.3 update
    I need some help. After the OTA update to 4.3 on my Nexus 4, my phone will not connect to my PC. It will still charge after connecting to any USB port on my computer but not connect. I've tried different cables and different computers and still nothing. I had no problems connecting prior to 4.3. I've searched various forums and tried various methods. This includes having the phone in developer mode and enabling "USB debugging", switching from PTP to MTP and vice versa, trying to locate drivers on the internet, and downloading the SDK manager. I've never rooted my phone before and want to to enable the LTE radios which requires rooting as well as connecting to my computer. Any suggestions?
  2. #2
    Kevin OQuinn's Avatar
    AC Team Emeritus
    Posts
    Global Posts
    9,908 Global Posts
    Carrier
    Stock
    Default Re: Nexus 4 not connecting to PC after Android 4.3 update
    You might need to update to the latest version of the SDK/ADB. Maybe also uninstall and reinstall the drivers.
    I believe I downloaded the current SDK/ADB from the Android developers page and still no luck with that. The other thing is I can not find the drivers on my computer. I've looked in Device Manager and there is nothing related to Android.
  4. #4
    To change your device's USB connection options, touch Settings > Device > Storage > Menu > USB computer connection.
    https://support.google.com/nexus/4/answer/2840804?hl=en
    i tried it and my nexus is connecting now..
  5. #5
    Where are touch settings ???
  6. #6
    Thnx to the ans. now am able to connect my nexus 4 to PC
  7. #7
    hey... any luck finding solution to your problem? am facing the same problem as well. even factory restore dosnt help...
  8. #8
    go to Settings > Storage > (hit the top right options button, should look like three virtical dots > USB computer connection.> then check "Media device (MTP)" and then browse your current drives on your PC and you should see NEXUS 7.
    - Joe
  9. #9
    flash Android 4.2's kernel. it shud work then
  10. #10
    Quote Originally Posted by harpreet singh11 View Post
  11. #11
    how you going to flash it to 4.2 when you cant connect the device to a pc?
  1. Nexus 4: camera error - can't connect to the camera
    By kim2kimi in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-17-2014, 09:54 AM
  2. Picking up my S4 from VZ today (hopefully) and need to know
    By o2bnclemson in forum Samsung Galaxy S4
    Last Post: 08-11-2013, 11:38 PM
  3. Rooting my nexus 7 OG
    By anonymous495876038576 in forum Google Nexus 7 Tablet (2012)
    Last Post: 08-08-2013, 04:41 PM
  4. Brightness Widgets don't work after latest update
    By JohnnyBravo602 in forum T-Mobile HTC One
    Last Post: 08-08-2013, 04:23 PM
  5. Replies: 2
    Last Post: 08-08-2013, 03:10 PM
