1. fastcaster's Avatar
    I bought a new Galaxy S3 in June and have been having trouble with the battery life. I've viewed numerous threads and websites and have turned off almost all features that are available on the phone. I only use the phone for texting, internet browsing, and occasional app usage, but my battery drains incredibly quickly. Here are a few examples of my problems:
    1) Last night I charged the phone to 100% and then turned it off. When I powered it on this morning the battery was at 89%.
    2) I haven't used the phone once today it is already at 70% life. This has occurred over the course of 3 hours as it has sat in my desk with no usage.
    3) When I use a battery application it gives me a normal reading of my estimated remaining battery life. When fully charged the app estimates that I have about 21 hours of usage left. In actual practice this number is closer to 8 hours.
    I have no idea what to do. I bought this to make my life easier but it seems like a big headache now. My last remaining idea is to do a factory reset. Does anyone else have any more advice? I've attached two pictures for assistance.
    Attached Thumbnails S3 Mega Battery Drain Issues-screenshot_2013-08-31-11-44-42.png   S3 Mega Battery Drain Issues-screenshot_2013-08-31-11-44-53.png
    09-01-2013 09:48 PM
  2. Golfdriver97's Avatar
    Welcome to the forums!
    You can try to reboot into recovery and clear cache. That may help if the drain is caused by conflicting data. Here is how: [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
    09-01-2013 11:07 PM
  3. fastcaster's Avatar
    Thanks for the advice. This was one of the first things I did, but I went ahead and did it again to see if it made any difference. So far it seems like my battery is draining as quickly as before. I've just finished charging and it's down to 92% after about 20 minutes. Should I go ahead and just do a backup and restore? I really have no idea what the problem is..
    09-02-2013 07:41 AM
  4. Golfdriver97's Avatar
    How old is the device? Have you considered a replacement battery?
    Sent from a SlimROM S3.
    09-02-2013 08:44 AM
  5. fastcaster's Avatar
    It's practically brand new. I bought it at the end of June this year.
    09-02-2013 08:46 PM
  6. josiahlikesminecraft's Avatar
    I would either get a new battery or do a factory reset with Odin.
    Posted via Samsung S3
    09-02-2013 08:51 PM
  7. fastcaster's Avatar
    Well, I'm not going to spend money on buying a new battery after buying a brand new smart phone about 3 months ago. I guess I'll go ahead and just do a factory reset. I was hoping to find some more personalized advice on the forums, but none seems forthcoming.
    09-04-2013 01:33 AM
  8. angry mustache's Avatar
    If it is only a few months old, the battery should still be covered by the warranty. If the factory reset doesn't work, if there is a carrier or Samsung store in your area take it in and have it switched out.
    ETA: If you haven't done the reset yet, try booting into recovery mode and wiping the cache partition first to see if that helps any.
    09-04-2013 12:09 PM
  1. Bluetooth Audio Issues with Car Stereo
    By dpw2atox in forum Moto X (2013)
    Last Post: 05-16-2015, 12:41 AM
  2. Need Help with galaxy S3
    By c_h_r_i_s_p in forum Samsung Galaxy S3 in Canada (Bell/Telus/Rogers)
    Last Post: 10-02-2013, 11:57 PM
  3. S3 Screen not functioning - Green Lines/Touch Screen not responding
    By jessicaamber in forum Samsung Galaxy SIII I9300
    Last Post: 09-07-2013, 01:22 AM
  4. Not able update my s3
    By sahilarya92 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-06-2013, 03:53 PM
  5. No offline charging+dead battery = bootloop
    By Silas178 in forum LG Optimus S
    Last Post: 09-02-2013, 08:34 AM
