Results 1 to 7 of 7
    Mark Anthony De Guzman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default samsung note 2 clone jb 4.1 internal memory problem
    please help on what should i do
    i have 12 gb internal memory and used only is 100mb and available is 300mb please help.
    Attached Thumbnails Attached Thumbnails samsung note 2 clone jb 4.1 internal memory problem-img_1367123.jpg   samsung note 2 clone jb 4.1 internal memory problem-img_1367123.jpg
  2. #2
    Haalcyon's Avatar
    Banned
    Posts
    Global Posts
    8,871 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM 10.2
    Default Re: samsung note 2 clone jb 4.1 internal memory problem
    You could try a factory reset and see if that resolves it.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i have already tried factory reset still the same problem. any other options?
  4. #4
    rnarias7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Samsung galaxy 2 memory problem
    I have the same problem when i use the camera or the videocamera, i found that it create some much space and it save it on file DCIM on thumbnails, but if you delete the problem is fixed temporally and it will happen again, so i need to know how to change the thumbnail option to avoid the creation of excess memory, Any ideas???
  5. #5
    Robin De Raedt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm Having the same problem. I tried many thing but nothing works
  6. #6
    Deanig_12's Avatar
    Posts
    Global Posts
    2,445 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have you all tried reseti g the cache?
    Sent from my C6603 using AC Forums mobile app
  7. #7
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It has something to do with the camera, if you take a picture the file returns again
  1. Samsung Galaxy S3 Keyboard Issues
    By gl122683 in forum Samsung Galaxy S3
    Last Post: 03-21-2014, 02:42 AM
  2. Problem with picture size
    By AllisonWi in forum Google Chromecast
    Last Post: 11-16-2013, 04:01 PM
  3. Will Kit Kat be coming to Galaxy Note or S series?
    By howserow in forum Android 4.4 KitKat
    Last Post: 11-05-2013, 09:03 AM
  4. note 3 case
    By Rohit Ramesh1 in forum Samsung Galaxy Note 3
    Last Post: 11-03-2013, 09:22 PM
  5. Any1 with problems with Google order??
    By Podolsky in forum Google Nexus 5
    Last Post: 11-03-2013, 02:12 AM
