Results 1 to 11 of 11
    MTHall720's Avatar
    Posts
    Global Posts
    34 Global Posts
    Default Battery drain--Which apps?
    Will all the apps on your phone either make a difference in battery life by simply having them OR just the ones that load on your home screens?
    Sent from my SCH-I535 using Tapatalk
  2. #2
    Default Re: Battery drain--Which apps?
    beware of anything that autosyncs in the background.
    Thanked by:
  3. #3
    Home Screen, Menu Key, Settings, More, Battery. A list of the battery drain percentages. The top name is the largest battery drain. My list shows Screen at 52% of the battery drain. For me the Auto brightness setting is bad. Best is to set fixed brightness at as low a level as workable and change setting if your in bright sunlight. Buying a smart phone with very large screen means large battery drain. My second item is Maps at 19%. I did use Maps. Obviously the highest % users are the items to investigate for reductions.
    One way to get Apps usage is the app GSam Battery Monitor, available on Google Play for free. When I select that I get a list. One of the items listed is App Usage. It lists all apps and their % usage down to 0.1%. Go thru the list and choose what is using battery and you don't use the app. Go to Application Manager, select the app and Force Stop. I find shutting down unused apps is worthwhile. Some factory stuff will restart itself but most will stay off. You can also investigate individual app settings, background settings, blah, blah. Choose no sound alerts or simple short sound. Battery drain is impacted by low/noisy signals from the cell towers, WIFI availability. Airplane mode will give you a clue to how low can you go when phone idle. Probably easier to buy a second battery. :-)
    Ray
    Thanked by:
  4. #4
    Stop the research, and simply turn off location reporting and location history under location settings. It will NOT affect any functionality in terms of GPS location. I did a lot of research like this and found that to be the issue
    Sent from my HTC One using Tapatalk
    MTHall720's Avatar
    Posts
    Global Posts
    34 Global Posts
    Thanks Very Much.
  6. #6
    I have a GS3 and I just did the 4.3 update. I was messing around with some of the new features and my battery has been lasting ALOT LONGER than it used to. I've been texting surfing, and FB all day like i normally do, my phone has been off the charger since 8am, its minutes after 4pm and I am at 58%. Before, normally, my battery would be on or under 50% just shy if 11am.
    If you limit your launch by default applications, Im sure your battery will last much longer. When I found the list, it was at least 20-30 apps deep. I limited it to about 10. Just did a screen shot for ya
    Thanked by:
    MTHall720's Avatar
    Posts
    Global Posts
    34 Global Posts
    Thanks very much to everyone I will post an update. How do get the updated 4.3?
  8. #8
    bluetooth also drains battery.
    MTHall720's Avatar
    Posts
    Global Posts
    34 Global Posts
    Is there a way to tell which h apps need to run at start up so no problems?
    Is there such h a thing as a super long lasting battery with more capacity than the standard one?
  10. #10
    You can try something like this.
  11. #11
    How do you set the limit to 10 apps? I have a GS3 also (bought in Nov of 2012) and I'm running 4.3 I can't find a screen where I can set the number of apps running.
  1. Apps disappearing...
    By Sarah Hart in forum General Help and How To
    Last Post: 03-19-2014, 04:57 PM
  2. Replies: 7
    Last Post: 01-08-2014, 12:39 PM
  3. In APP purchase block not working
    By ebross67 in forum General Help and How To
    Last Post: 12-13-2013, 02:41 PM
  4. LG G Pad 8.3 Google Play Edition: Better Battery Life?
    By noogle in forum LG G Pad 8.3 Google Play edition
    Last Post: 12-12-2013, 05:18 PM
  5. Plume (Twitter app) photos/videos
    By edithswanneck in forum Android Applications
    Last Post: 12-12-2013, 10:52 AM
B
