Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By B. Diddy
    Default NEED HELP! “Unfortunately, com.android.preference.help has stopped" KEEPS POPPING UP!
    This error message keeps popping up every 15 minutes saying “Unfortunately, com.android.preference.help has stopped." And I click OK and it pops up again and again and AGAIN. I've restarted my phone to see if it helps but it doesn't. Its starting to become VERY annoying. Please help. New galaxy note 3, not rooted.
  2. #2
    Default Re: NEED HELP! “Unfortunately, com.android.preference.help has stopped" KEEPS POPPING UP!
    Welcome to Android Central! Have you Disabled any system apps? If so, one of them might be needed for whatever process is failing.
    If you haven't disabled any apps, then try going toyour App Manager or Settings>Apps​, tapping the Menu button, and selecting "Reset all app preferences."
    Hi! I've hit the reset all app preferences and its still popping up. However, I did notice that it pops up a lot more when I'm updating my play store apps. I was doing an “update all" on all my apps that needed updating in my play store and it popped up for every app that was being updated. It was impossible to do anything on my phone because of the pop up message so I hit “stop" to stop the updating and the pop up messaged stopped. Sooooo.... what the heck is wrong with my phone??
    Oh, does it have anything to do with the “lookout app" on my phone? Because that's what is in my notification bar while updating my apps. Idk if that has anything to do with my error msg but please help!
  4. #4
    Try doing a system cache partition wipe, following these instructions. You won't lose any personal data or settings.
    Sorry, that didn't work either. I followed the instructions and it still popping up.
    Also, this black screen pops and and immediately disappears. Looks kind of like when you take a screen shot, is that spyware?? Should I just hard reset? :/
  7. #7
    Did you try clearing the cache in the play store app? You can also clear the data if you need to. It will rebuild itself when it syncs.
    Pat
    Nook Color - CM10.1 ( Jelly Bean 4.2.2) on eMMC
    Google Galaxy Nexus - stock Jelly Bean 4.3
    Galaxy Nexus 10 - stock KitKat 4.4.2
    Galaxy Nexus 7 (2nd Generation) - stock KitKat 4.4.2
    Chromecast
    Nexus 5 - stock KitKat 4.4.2
    Thanked by:
  8. #8
    Quote Originally Posted by patruns View Post
    That's a good idea--was going to my next suggestion, but patruns beat me to it!
    patruns likes this.
    No its still popping up.. :/
  10. #10
    UJ95x's Avatar
    Posts
    Global Posts
    5,537 Global Posts
    ROM
    Slim Kat 4.4.2 Build 3
    I don't think it's spyware. Sounds like it's just a system process that isn't working properly. Backup up your data and see if a hard reset fixes it
    Everything in this post is 100% accurate...I think
    R.I.P. Motorola...and what could have been the best smartphone line ever
  1. Battery has gone south
    By rbess1965 in forum Droid RAZR MAXX HD
    Last Post: 01-01-2014, 02:34 PM
  2. My Note 3 just drains battery quicker than before. please help. :)
    By marktika in forum Samsung Galaxy Note 3
    Last Post: 12-27-2013, 01:11 PM
  3. Back to Android!
    By Mugen_Cris in forum Introductions
    Last Post: 12-24-2013, 03:01 PM
  4. i need help I factory rest a custom rom on my lg esteem
    By johnchambersj in forum Android 2.3 Gingerbread
    Last Post: 12-23-2013, 01:03 PM
  5. Replies: 1
    Last Post: 12-23-2013, 09:40 AM
B
