Results 1 to 2 of 2
    Default Battery drain?
    My HTC One running software version 4.3 loses battery life at about 1% per minute when in use. This just started occurring recently. When I'm using it I'm mostly messaging or browsing facebook/other apps which used to work fine. I have battery saver on and also applied some other tips I read about to preserve battery life. When I check battery usage it says the android system is using 93% of the battery. Is there a way to reload the software or go back to an older version?
  2. #2
    Default Re: Battery drain?
    A couple of things you can try:
    1. Do a system cache partition wipe, which can sometimes clear out an old piece of data stuck in the system cache that is messing things up (how about that for a highly technical explanation?). You won't lose any personal data or settings.
    2. Install a good battery monitor app like to get a more detailed breakdown of battery usage.
  1. Is this considered abnormal battery drain?
    By Infiniteloop7 in forum Google Nexus 5
    Last Post: 01-05-2014, 04:40 AM
  2. Replies: 23
    Last Post: 01-04-2014, 08:55 PM
  3. Battery!!
    By jumper809 in forum Moto X
    Last Post: 12-30-2013, 01:17 PM
  4. Battery drain.
    By Nana-Banyin Jonfiah VI in forum Samsung Galaxy Note 3
    Last Post: 12-30-2013, 09:29 AM
  5. battery drain with netflix?
    By denarok in forum LG G2
    Last Post: 12-29-2013, 08:25 PM
B
